Send signal from IR Led to Receiver (TSOP) on same arduino
#include <Arduino.h>
#include <IRremote.h>
#define IR_RECEIVE_PIN 6
#define IR_SENDER_PIN 3
  IrReceiver.begin(IR_RECEIVE_PIN);
  IrSender.begin(IR_SENDER_PIN);
  IrSender.sendSamsung(0x7, 0x7, 0);
  delay(5000);
  if (IrReceiver.decode()) {
    auto &data = IrReceiver.decodedIRData;
    if (data.protocol != UNKNOWN && data.numberOfBits >= 8) {
      IrReceiver.printIRResultShort(&Serial);
      Serial.println("RawData HEX");
      Serial.println(data.decodedRawData, HEX);
      delay(2000);
    IrReceiver.resume();
I try to send a signal from an IR led to a receiver on the same arduino. Does this work? What do I have to change? At the moment I dont jump into the IrReceiver.decode() section.
No, especially with that 5s delay :wink:
You need two separate arduinos for what you are looking for.
You need two cores to do what you want. While transmitting the core is busy and cannot receive. A second core could receive while the first is transmitting. This can be accomplished with two Arduino or one with two or more cores.
See Arduino-IRremote/examples/SendAndReceive/SendAndReceive.ino at master · Arduino-IRremote/Arduino-IRremote · GitHub
