Hello everyone,
I'm working on a GSM module project, where users need to be able to send SMS through a web platform and using the gsm module.
I'm using Arduino Mega 2560 + Ethernet Shield W5100 + SIM808 module
Here is the code:
Web Server
#include <SPI.h>
#include <Ethernet.h>
//SMS Include
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xA2, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 23);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
//SMS VARIABLES
#define MESSAGE_LENGTH 160
char message[MESSAGE_LENGTH];
char phone[16];
char datetime[24];
char phone_to[] = "xxxxxxx";
#define PIN_TX 12
#define PIN_RX 13
SoftwareSerial mySerial(PIN_TX,PIN_RX);
DFRobot_SIM808 sim808(&mySerial);//Connect RX,TX,PWR,
mySerial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection and the server:
//Ethernet.begin(mac, ip);
Ethernet.begin(mac);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//******** Initialize sim808 module *************
while(!sim808.init())
Serial.print("Sim808 init error\r\n");
delay(3000);
if( sim808.attachGPS()) {
Serial.println("Open the GPS power success");
//return true;
else {
Serial.println("Open the GPS power failure");
//return false;
void writeResponse(EthernetClient client) {
// send a standard http response header
Serial.println("SMS was sent - this is in writeResponse");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println();
client.println("SENT");
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
String req_str = "";
int data_length = -1;
boolean skip = false;
//int empty_line_count = 0;
while (client.connected())
if (client.available()) {
char c = client.read();
//Serial.write(c);
req_str += c;
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank && req_str.startsWith("GET")) {
writeResponse(client);
if (c == '\n' && currentLineIsBlank && req_str.startsWith("POST") && !skip) {
if(sendSms()) {
Serial.println("SMS was sent - this is in loop");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
//Serial.println(req_str);
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
bool sendSms() {
char msg[] = "test";
sim808.sendSMS(phone_to,msg);
//************* Turn off the GPS power ************
sim808.detachGPS();
Serial.println("SMS was sent - this is in function");
return true;
The SMS is received, but the response in the writeResponse function is never received by the client. The serial write works ok btw.
The serial output looks like this:
client disconnected
I'm using 5V 1A power supply that is powering both the arduino and SIM808 GSM modules. The arduino is connected with usb to PC too.
If I disable the SMS sending in sendSms() function, the response is sent OK.
But with the SMS sending code enabled, the response is not sent.
Thanks in advance for your help
