Send text via bluetooth
Hello everyone!
I'm doing some tests sending and receiving data via bluetooth on ESP32.
When I send a certain string value, the null value is sent with it. So I get "page1ok " instead of "page1ok". Is there a possibility for me to send without the null value? Or just dealing with the receiver's side of the message?
//By Evandro Copercini - 2018
//This example creates a bridge between Serial and Classical Bluetooth (SPP)
//and also demonstrate that SerialBT have the same functionalities of a normal Serial
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
String msgA;
String msgB;
int tela;
  SerialBT.begin("ESP32test"); //Bluetooth device name
  Serial.println("The device started, now you can pair it with bluetooth!");
  tela = 0;
  switch (tela)
    case 0:
      Serial.println("Pagina 0");
      if (SerialBT.available() > 0) {
        msgB = "";
        while (SerialBT.available() > 0) {
          char ch = SerialBT.read();
          msgB += ch;
          delay(5);
        Serial.println("Mensagem:");
        Serial.println(msgB);
        Serial.println("Verificando tela...");
        verificaTela();
    case 1:
      Serial.println("Pagina 1");
        msgA = "";
          msgA += ch;
          delay(5);
        Serial.println(msgA);
        if (msgA.startsWith("page")) {
        msgB = msgA;
          verificaTela();
  delay(20);
void verificaTela()
  Serial.println("TELA:");
  if (msgB == "page1") {
    //sendMessage("page1ok");
    String a = "page1ok";
    SerialBT.println(a);
    tela = 1;
  else if (msgB == "page0") {
    tela = 0;
void bluetooth(String a)
    a = "";
      a += ch;
      delay(5);
    Serial.println(a);
    verificaTela();
  delay(20);
Thanks!
Does it help if you use print instead of println?
I tried. But if I use print, the message is not received...
Try this to strip the null terminator
char buf[a.length()];
memcpy(buf, a.c_str(), a.length());
SerialBT.write(buf, a.length());
You may need to send a '\n' or some other character which the receiver is expecting.
Returns me the following error:
invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
So I changed to:
  SerialBT.write((uint8_t *)buf, a.length());
But it still didn't work, the message is not sent...
I can not confirm what you say.
I run this sketch on an ESP32
  uint8_t buf[a.length()];
  memcpy(buf,a.c_str(),a.length());
  SerialBT.write(buf,a.length());
  SerialBT.println();
The compiler doesn't complain when the buffer is declared as uint8_t.
This is what I see on the screen of the Serial Bluetooth Terminal App is use.
What is receiving the message?
