Send the 16-bit value as two 8-bit values
Original:
byte Data[2];
    B=B+1;
    Data[0]=data2[readIndex2]/256;
    Data[1]=data2[readIndex2]%256;
    if (A==1){
      if (B>=4){
      for(int j=0;j<2;j++)
Serial.write(Data[j]);
After the change:
byte Data[2];
    B=B+1;
    if (A==1){
      if (B>=4){
     Serial.write(0xCC);
     Serial.write((Data[j] >> 8) & 0xFF);
     Serial.write((Data[j] & 0xFF);
I don't know if this change is feasible. Help me directly with questions. My idea is to send it in 2 passes.
int d16;
Serial.write(lowByte(d16));
Serial.write(highByte(d16));
GolamMostafa: int d16; Serial.write(lowByte(d16)); Serial.write(highByte(d16));
I was doing this the 'hard' way
Thanks
or if you want to see what you do and not rely on Arduino's macros, just use shifting and masking
  int16_t w = 0xAABB;
  Serial.write(w & 0xff); // LsB
  Serial.write(w >> 8);   // MsB
void loop() {}
(you could use casting for documentation and type coherence but write will get the first byte only anyway)
and of course you could also let the write function do that for you:
  int16_t w = 0xAABB;
  Serial.write((uint8_t*) &w, sizeof(w)); // LsB first as little endian
void loop() {}
