Send the ADC data to pc in the form of packet...
I'm trying to send the ADC data to pc in the form of packet in Arduino due.
Example : Create a packet, that packet contain 6 channels data and 1 start byte ,1 stop byte. Totally the size of the packet is 8 byte.
how to create a packet ?...
byte packet[8];
packet[0] = 0xFF; //header
packet[7] = 0x0D; //stop
Then fill packet [1] to packet [6] and send?
for(int ii = 0; ii < 6; ii++)
packet[ii+1] = channel[ii];
udp.write(packet, 8);
Something like this? please post the code you have now…
iyappan:
What type of a "packet" do you mean?
Serial? TCP? UDP? UPS?
jurs:
UPS?
Took me a while() before I got it...
Actually i read the data in C++ ( Serial.cpp, Serialclass.h )
(http://playground.arduino.cc/Interfacing/CPPWindows), My code is
void setup
adc_init();
adc_interrupt_enable(0x 81);
write_protect_mode(true);
adc_start();
void loop
 while( check_DRDY()==1)
packet[0] = 0xFF;
packet[7] = 0x0D;
for(int i = 0; i  < 6; i++)
packet[i+1] = channel[i];
Serial.write(packet,8);
nothing its showing in command prompt…
Posting Arduino code that could actually compile would be useful.
Posting the C++ code that thinks it can read the Arduino data would be useful.
A "command prompt" is something like:
Hey, you, enter a value >
Why you would be using data from the Arduino to formulate the prompt escapes me.
iyappan:
What the hell is this 'check_DRDY()' function call doing?
Most likely it doesn't return 1.
And because this function 'check_DRDY()' that you don't show as a source code does not return 1, your loop function doesn't do anything at all.
The source code is my own code , My system is remote desktop connection so i can’t sent the code. Adc program is already avilable in arduino . So please using that code…
Give any idea about the Serial packet… any example…
I have a problem. My code doesn’t work. I can’t (or won’t) show you the code on the PC, but I’ll show you some crap that might bear a passing resemblance to my Arduino code. I still need help.
Have I paraphrased your post so far correctly?
iyappan:
The source code is my own code , My system is remote desktop connection so i can't sent the code. Adc program is already avilable in arduino . So please using that code...................
Give any idea about the Serial packet.... any example...
adc is not in my arduino IDE...
and try replacing:
the channel with your own analog input.
Discard the while() loop, does it work then?
And I do have to agree with PaulS, If you can't post your code, we can't help you...
