Hello, please i'm trying to upload data to thingspeak and i found this code very efficient. The problem is instead of sending only one sensor value or field to thingspeak like it's done in this code, i want to send three. I want to send say voltage, current and frequency value to thingspeak. Please apart from the write key in this code what else will i change to make this code send the three fields i want to send.
#include <SoftwareSerial.h>
//SIM800 TX is connected to Arduino D8
#define SIM800_TX_PIN 8
//SIM800 RX is connected to Arduino D7
#define SIM800_RX_PIN 7
//Create software serial object to communicate with SIM800
SoftwareSerial serialSIM800(SIM800_TX_PIN,SIM800_RX_PIN);
#define TIMEOUT 30000
int8_t answer;
int onModulePin = 13;
char aux_str[100];
int x = 0;
int attempts;
char apn[] = "internet.movistar.ve";
//char url[ ]="api.thingspeak.com/update?api_key=PHRFH37I50UK9MGF&field1=20.50";
char url[ ]="api.thingspeak.com/update?api_key=PHRFH37I50UK9MGF&field1=";
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 15000L; // delay between updates, in milliseconds
pinMode(onModulePin, OUTPUT);
//Begin serial comunication with Arduino and Arduino IDE (Serial Monitor)
while(!Serial);
//Being serial communication with Arduino and SIM800
serialSIM800.begin(9600);
Serial.println("Starting...");
power_on();
delay(3000);
//Serial.println("AT+HTTPPARA=\"URL\",\"www.castillolk.com.ve/WhiteList.txt\"\r\n");
while( (sendATcommand("AT+CREG?\r\n", "+CREG: 0,1\r\n", 500) ||
sendATcommand("AT+CREG?\r\n", "+CREG: 0,5\r\n", 500)) == 0 );
/* sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r\n", "OK\r\n", TIMEOUT);//sets Contype
snprintf(aux_str, sizeof(aux_str), "AT+SAPBR=3,1,\"APN\",\"%s\"\r\n", apn);//sets APN
sendATcommand(aux_str, "OK\r\n", TIMEOUT); */
connectToNetwork();
initHTTPSession();
HTTPRequest();
// if 15 seconds have passed since your last connection,
// then connect again and send data
if (millis() - lastConnectionTime > postingInterval) {
HTTPRequest();
int8_t sendATcommand(const char* ATcommand, const char* expected_answer1, unsigned int timeout) {
uint8_t x = 0, answer = 0;
char response[100];
unsigned long previous;
memset(response, '\0', 100); // Initialize the string
delay(100);
while (serialSIM800.available())
{ //Cleans the input buffer
serialSIM800.read();
Serial.println(ATcommand); // Prints the AT command
serialSIM800.write(ATcommand); // Sends the AT command
x = 0;
previous = millis();
// this loop waits for the answer
do
////if (Serial.available() != 0) {
if (serialSIM800.available() != 0)
////response[x] = Serial.read();
response[x] = serialSIM800.read();
x++;
// check if the desired answer is in the response of the module
if (strstr(response, expected_answer1) != NULL)
answer = 1;
// Waits for the asnwer with time out
while ((answer == 0) && ((millis() - previous) < timeout));
return answer;
void power_on()
uint8_t answer = 0;
Serial.println("On Power_on...");
// checks if the module is started
answer = sendATcommand("AT\r\n", "OK\r\n", TIMEOUT);
if (answer == 0)
// power on pulse
digitalWrite(onModulePin, HIGH);
delay(3000);
digitalWrite(onModulePin, LOW);
// waits for an answer from the module
while (answer == 0)
// Send AT every two seconds and wait for the answer
Serial.println("Trying connection with module...");
void restartPhoneActivity()
do
sendATcommand("AT+CFUN=0\r\n", "OK\r\n", TIMEOUT);
delay(2000);
answer = sendATcommand("AT+CFUN=1\r\n", "Call Ready\r\n", TIMEOUT);
}while(answer == 0);
void connectToNetwork()
attempts = 0;//tries 3 times or gets on the loop until sendATcommand != 0
while (sendATcommand("AT+SAPBR=1,1\r\n", "OK\r\n", TIMEOUT) == 0)
delay(5000);
attempts = attempts + 1;
if(attempts > 2)
restartPhoneActivity();
attempts = 0;
void initHTTPSession()
while (sendATcommand("AT+HTTPINIT\r\n", "OK\r\n", TIMEOUT) == 0)
connectToNetwork();
void HTTPRequest()
////snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\"\"%f\"\r\n", url, light);
float light = readLDR();
char sensorValue[6];
dtostrf(light,5,2,sensorValue);
snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\%s\"\r\n", url, sensorValue);
delay(3000);
while (sendATcommand("AT+HTTPACTION=0\r\n", "+HTTPACTION: 0,200,", TIMEOUT) == 0)
delay(5000);
if(attempts > 2)
sendATcommand("AT+SAPBR=0,1\r\n", "OK\r\n", 2 * TIMEOUT);
sendATcommand("AT+HTTPTERM\r\n", "OK\r\n", TIMEOUT);
connectToNetwork();
initHTTPSession();
////snprintf(aux_str, sizeof(aux_str), "AT+HTTPPARA=\"URL\",\"%s\"\r\n", url);
light = readLDR();
attempts = 0;
Serial.println("Successfully uploaded");
// note the time that the connection was made
lastConnectionTime = millis();
float readLDR()
//read the input on analog pin 0:
int sensorValue = analogRead(A0);
//Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
return voltage;
