Hi community, I try to sent via Xbee in API mode Time&Date from my DS1307 RTC and the problem here is when I read the Time&Date from the function -- if (RTC.read(tm)) {...---
it give me a this Example: 00:11:46 | 1/5/2021. So i Want to convert that data in a array of caracteres. When i have the arrays, I going to convert to HEX, and next I going to concatenate whith my FRAME in HEX, that I going to sent via Xbee.
This is my code.
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
#include <SoftwareSerial.h>
SoftwareSerial xbee(2, 3);
String formatoData;
byte packet[] = {};
//Trama de Datos: (FALTA VOLTAJE) La longitud de la trama nunca a variar, ya que el formato esta establecido para nunca variar.
//Formato de la data: XX.XX 00:11:46 01/05/2021
//Trama de datos
//7E 00 28 10 01 00 13 A2 00 41 4E F1 24 FF FE 00 00 58 58 2E 58 58 20 30 30 3A 31 31 3A 34 36 20 30 31 2F 30 35 2F 32 30 32 31 0D 34
// Encabezado de Trama: Delimitador, longitud,tipo de trama, direccion de destnatario. ESTO NO VARIA.
byte packet1[] = {0x7E, 0x00, 0x28, 0x10, 0x01, 0x00, 0x13, 0xA2, 0x00, 0x41, 0x4E, 0xF1, 0x24, 0xFF, 0xFE, 0x00, 0x00};
//Data: ESTO SI VARIA.
// 58 58 2E 58 58 20 30 30 3A 31 31 3A 34 36 20 30 31 2F 30 35 2F 32 30 32 31 0D
//Checksum: Esto si varia.
//34
byte packet2[] = {};
//Declaro e inicializo un array tipo char para almacenar el string XX.XX 00:11:46 01/05/2021
char packetString[] = {};
xbee.begin(9600);
while (!Serial) ; // wait for serial
delay(200);
Serial.println("DS1307RTC Read Test and Send Test w/ Xbee API");
Serial.println("-------------------");
tmElements_t tm;
if (RTC.read(tm)) {
Serial.print(" ");
char hora[] ={tm.Hour};
print2digits(hora);
Serial.write(':');
char minuto[] ={tm.Minute};
print2digits(minuto);
Serial.write(':');
char segundo[] ={tm.Second};
print2digits(segundo);
Serial.print(" ");
char dia[] ={tm.Day};
print2digits(dia);
Serial.write('/');
char mes[] ={tm.Month};
print2digits(mes);
Serial.write('/');
char years [] = {tmYearToCalendar(tm.Year)};
Serial.print(years);
//Pasar de ASCII a HEX
// Formato ASCII :00:11:46 | 1/5/2021
// Formato HEX : 30 30 3A 31 31 3A 34 36 20 7C 20 31 2F 35 2F 32 30 32 31 0D
//xbee.write (packet , sizeof(packet)); // Manda el mensaje al nodo PC
delay(3000);
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
When I run this i have this in my serial monitor :
2299:2298:2297 2296/2295/⸮e
