Send time from OS X terminal to Arduino via serial
Hi there
I’ve built a basic DS1307-based clock using the DS1307 library, and I want to add the capability to send the Unix timestamp over serial.
I know you can use “date +%s” to print the Unix timestamp within the terminal, and I can save that output to a txt file using date +%s > out.txt. Is there a way I can pipe it to the serial port? I’ve tried the following, but it doesn’t work, and I have to exit using ctrl+c. Ideally I’d like to terminate the string with a newline, as that’s how my code is set up at the moment. It just means it’s easier to tell the end of the incoming message.
date +%s > /dev/tty.usbserial
Here’s the code if anyone is interested. It works when receiving numbers over serial, so at least that’s working.
Any help would be greatly appreciated!
#include <DS1307RTC.h>
#include <Time.h>
#include <Wire.h>
#include <Adafruit_CharacterOLED.h>
// initialize the library with the numbers of the interface pins
Adafruit_CharacterOLED lcd(6, 7, 8, 9, 10, 11, 12);
char *separator[2] = {" ", ":"};
const char *monthNames[12] = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
byte tickToggle;
byte separatorSwitcher;
  lcd.begin(16, 2);
    while (Serial.available() > 0) {
    // look for the next valid integer in the incoming serial stream:
    unsigned long timeFromComputer = Serial.parseInt();
    // look for the newline. That's the end of your
    // sentence:
    if (Serial.read() == '\n') {
      if  (RTC.set(timeFromComputer) == true)
        lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print("Sync Successful!");
        delay(1500);
        lcd.clear();
  tmElements_t tm;
  if (RTC.read(tm)) {
    if (tickToggle != tm.Second) {
      if (separatorSwitcher < 1){
        separatorSwitcher++;
        separatorSwitcher = 0;
    lcd.print(tm.Day);
    lcd.print(' ');
    lcd.print(monthNames[tm.Month - 1]);
    lcd.print(' ');
    lcd.print(tmYearToCalendar(tm.Year));
    lcd.setCursor(0, 1);
    print2digits(tm.Hour);
    lcd.print(separator[separatorSwitcher]);
    print2digits(tm.Minute);
    print2digits(tm.Second);
    tickToggle = tm.Second;
    if (RTC.chipPresent()) {
      lcd.print("No Time Set!");
      lcd.print("Upload SetTime");
      lcd.print("Circuit Error");
    delay(9000);
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    lcd.print("0");
  lcd.print(number);
