Hi! My wish is to send a specific OSC message to Qlab over UDP when the button is pressed and to send another message when the button is released. I copied from examples and other sketches found on the internet but I keep having the same problem.
I am reading the incoming messages to my computer with OSCulator and looks like one of the two messages (when button is released) is received correctly, when I press the button I have a "OSC UDP server error" shown in OSCulator and no message is received.
I am sure it is a simple problem, but I am new to programming and I need some help!
Thank you!
Here is the code:
Make an OSC message and send it over UDP
Adrian Freed
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OSCMessage.h>
int buttonPin1 = 12;
int buttonValue1 = HIGH;
boolean buttonChanged = false;
EthernetUDP Udp;
//the Arduino's IP
IPAddress ip(192, 168, 1, 177);
//destination IP
IPAddress outIp(192, 168, 1, 75);
const unsigned int outPort = 53000;
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // you can find this written on the board of some Arduino Ethernets or shields
pinMode(buttonPin1, INPUT_PULLUP);
Ethernet.begin(mac,ip);
Udp.begin(8888);
OSCMessage play("/cue/1/go/");
OSCMessage stp("/cue/0/go/");
if (digitalRead (buttonPin1) != buttonValue1)
buttonChanged = true;
buttonValue1 = digitalRead(buttonPin1);
if (buttonChanged == true)
Serial.print("Button: ");
Serial.println(buttonValue1);
if (buttonValue1 == 1)
Udp.beginPacket(outIp, outPort);
play.send(Udp);
Udp.endPacket(); // mark the end of the OSC Packet
play.empty(); // free space occupied by message
delay (20);
if (buttonValue1 == 0)
stp.send(Udp);
stp.empty(); // free space occupied by message
delay (20);
Thank you so much for your reply, I included your suggestion and I can see that I am printing "send msg1" and "send msg2" correctly on the serial monitor according to the button state.
The problem is still the OSC, the first message ("/cue/1/start") is delivered correctly but the second one ("/cue/0/start") still does not work!
I must be missing some information about how to handle OSC messages through UDP probably. I really do not understand the problem!
Here is the new code:
Adrian Freed
#include <SPI.h>
const int buttonPin1 = 12;
EthernetUDP Udp;
//the Arduino's IP
//destination IP
byte mac[] = {
Udp.begin(8888);
int but = digitalRead(buttonPin1);
OSCMessage play("/cue/1/start");
OSCMessage stp("/cue/0/start");
if (buttonValue1 != but) {
buttonValue1 = but;
delay (10);
if (1 == but) {
Serial.println ("send msg1");
play.send(Udp);
else {
Serial.println ("send msg2");
stp.send(Udp);
delay (20);
OSC requires a value after the address. So the entire code for sending something with OSC would be:
OSCMessage msg(address);
msg.add(value);
Udp.beginPacket(clientIP, port);
msg.send(Udp); // send the bytes to the SLIP stream
