Send variable with RF69 (possible data type issue)
Hi, I'm working with a custom board using the Atmega328PB with a RFM69HCW 915 MHz radio module.
I have two boards, one is TX, the other RX.
They send data back and forth using the example code given by the Radiohead Packet Library, and I have verified the hardware.
The examples show how to send known data, I am having trouble sending variables.
This works (from the TX example), and the LED blinks on the RX to show that it works:
char radiopacket[20] = "Hello World #";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending "); Serial.println(radiopacket);
rf69.send((uint8_t *)radiopacket, strlen(radiopacket)); // Send a message!
// \param[in] data Array of data to be sent
// \param[in] len Number of bytes of data to send (> 0)
// \return true if the message length was valid and it was correctly queued for transmit
This does not send the variable sensorValue:
int sensorValue = analogRead(A2);
char radiopacket[10];
snprintf(radiopacket, sizeof(radiopacket), "ADC:%d", int(sensorValue));
rf69.send((uint8_t *)radiopacket, strlen(radiopacket)); // original code byte, strlen (returns long int)
It seems that rf69.send is needed to send the data, but I don't know how to get it into the correct format.
Thanks in advance!
How to you know it is not working? Both examples just send a string
Hi blh64
I have LEDs set up to blink in a cycle if the data is sent. So the first example sends the data perfectly (and it should as it is one of the examples from the people who made the libraries).
The second code does not result in LEDs blinking, although this line prints on the serial monitor.
It is the above line that needs to get into the rf.send() format.
Thanks in advance~!
Sophi:
what is that format? what specifically are you looking for in the received message?
is your code that blinks an LED looking for a specific message (e.g. "Hello World #") or any message?
