Hallo und vielen Dank für deine Antwort,
ich würde das schon gern selbst machen wollen, will ja auch was lernen
Meinst du mit nur Temp gesendet wird das im buf [2] ?
wenn ich das in 0xe ändere was für die Luftfeuchte steht passiert nichts auser chaotische Werte.
Kannst du mir da nochmal auf die Sprünge helfen?
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 3 // PIN # for DHT22 Temperature Sensor
#define TXPIN 1 // PIN # for 433Mhz Transmitter
#define LEDPIN 0 // PIN # for LED Indicator
#define DHTTYPE DHT22 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
// NOTE: For working with a faster chip, like an Arduino Due or Teensy, you
// might need to increase the threshold for cycle counts considered a 1 or 0.
// You can do this by passing a 3rd parameter for this threshold. It's a bit
// of fiddling to find the right value, but in general the faster the CPU the
// higher the value. The default for a 16mhz AVR is a value of 6. For an
// Arduino Due that runs at 84mhz a value of 30 works.
// Example to initialize DHT sensor for Arduino Due:
//DHT dht(DHTPIN, DHTTYPE, 30);
unsigned long msg_timer = 15000; // Transmits a signal every 1 minute
unsigned long msg_gap = 32; //gap between packets
char buf[11]; //message to be built
// Serial.begin(9600);
//Serial.println("Wireless Temp");
pinMode(LEDPIN,OUTPUT);
pinMode(TXPIN, OUTPUT);
dht.begin();
// Changed int to float
// num is in Celsius. Ex) 26.30
// Brian May 24, 2015
void make_message(float num) {
// make up a TC6U message from the integer num (-500 to 499)
// parity table 0 1 2 3 4 5 6 7 8 9
char ptable[]={
0,1,1,2,1,2,2,3,1,2 }; //number of bits set
int p; //parity bit
char h,t,d; //hundreds,tens,digits
p=0; //clear parity
// preamble
buf[0] = 0;
buf[1] = 0xa; //message length and start bits
buf[2] = 0; //type = temperature
buf[3] = 0xf; //device ID
buf[4] = 0x0; //bottom bit is parity
// Adjusted digit mismatch in LA CROSSE WS-9016TWC
num = num * 10;
// encode the integer
num = num+500;
h = num/100;
buf[5] = h; //save hundreds
p += ptable[h]; //update parity calculation
num = num - h*100;
t = num/10;
buf[6] = t; //save tens
p += ptable[t]; //update parity
d = num - t*10;
buf[7] = d; //save digits
p += ptable[d];
buf[8] = h; //second copy of hundreds digit
buf[9] = t; //second copy of tens digit
//if value parity odd, set message parity bit
if ( (p&1) == 1) buf[4] |= 1;
//calculate and store checksum
buf[10] = (buf[1]+buf[3]+buf[4]+buf[5]+buf[6]+buf[7]+buf[8]+buf[9])&0x0F;
void send_one(char s) { //s=1 for short TXPIN off. 4th bit of quartet
digitalWrite(TXPIN,HIGH);
delayMicroseconds(588);
digitalWrite(TXPIN,LOW);
if (s) delayMicroseconds(1020);
else delayMicroseconds(1088);
void send_zero(char s) { //s=1 for short TX off, 4th bit of quartet
delayMicroseconds(1400);
void send_burst(char *msg) {
char i,c;
for(i=0; i<12; i++) {
c = *msg++; //values in lower 4 bits
//unroll inner loop, send a quartet
if(c&8) send_one(0);
else send_zero(0);
if(c&4) send_one(0);
else send_zero(0);
if(c&2) send_one(0);
else send_zero(0);
if(c&1) send_one(1); //"short tx off" (1020 us) for last bit
else send_zero(1);
void send_message(float num) {
digitalWrite(LEDPIN,HIGH);
make_message(num);
send_burst(buf);
delay(msg_gap);
send_burst(buf);
digitalWrite(LEDPIN,LOW);
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float t = dht.readTemperature();
float h = dht.readHumidity();
// Check if any reads failed and exit early (to try again).
if (isnan(t)) {
// Serial.println("Failed to read from DHT sensor!");
return;
// Serial.print(t);
//Serial.println(" *C\t");
send_message(h);
send_message(t); // t is in Celisius. Ex) 26.30
delay(msg_timer);
