Sendind Strings to a device following a protocol
Dear friends;
I need to send several strings to a device. But in order to work the device requires that I send according a protocol. For example to send the string "hello" at position X =5 and Y =12 i will need send: (Serial.write)
3 fixed bytes (commands to write )
1 byte (position X variable = 0x05)
1 byte (position Y variable = 0x0C)
10 bytes : (0xA3) , ("h"), (0xA3,("e"),(0xA3), ("l"),(0xA3),("l"),(0xA3),("o") (need to add 0xA3 (fixed) before each character of the string)
1 byte (chksum) chksum = exor of all above bytes
What is the best way to do this ?
I mind something like:
x= 5;
y=12;
mystring = "hello";
callMyFunction();
void callMyFuncion {
????? how implement this function ?
I needed to send data (in bytes). The actual output is in string format, i.e. 45.3 is "4" "5" "." "3"
So I created an array of bytes. Filled in the locations I needed to and set it out using the UART.
void sendHubitat(){
	zArray[0] = mHumidity;
	zArray[1] = round(mTemperature);					// units)
	zArray[2] = round((mTemperature - zArray[1])*10);	// tenths
	//zArray[3] = ETX  pre declaired global.
	Serial.write(zArray,sizeof(zArray));
something like this maybe:
void writeText(uint8_t x, uint8_t y, char *str) {
  int i = 0;
  uint8_t checksum = 0;
  //send write command
  Serial.write(writecommandbyte1); //update with the ACTUAL byte value!
  checksum ^= writecommandbyte1; //update checksum
  Serial.write(writecommandbyte2); //update with the ACTUAL byte value!
  checksum ^= writecommandbyte2; //update checksum
  //send 'x' value
  Serial.write(x);
  checksum ^= x; //update checksum
  //send 'y' value
  Serial.write(y);
  checksum ^= y; //update checksum
  //send string
  while (str[i] != '\0') {
    Serial.write(0xA3);
    checksum ^= 0xA3; //update checksum
    Serial.write(str[i]);
    checksum ^= str[i]; //update checksum
    ++i;
  //send checksum
  Serial.write(checksum);
  uint8_t x = 5;
  uint8_t y = 12;
  char str[] = "hello";
  Serial.begin(9600); //update baudrate to match device speed
  writeText(x, y, str);
note that you did not provide the write command byte so I could not include in it this sample code. please update accordingly.
Hope that helps....
consider
dispBuf
 01 02 03 05 0c a3 68 a3 65 a3 6c a3 6c a3 6f c8
#define BUF_SIZE  80
byte buf [BUF_SIZE];
byte prefix [] = { 1, 2, 3 };
int
msg1 (
    byte       *buf,
    int         maxByte,
    byte       *prefix,
    byte        x,
    byte        y,
    const char *s )
    if (BUF_SIZE < strlen(s) + 6)
        return -1;
    memcpy (buf, prefix, 3);;
    buf [3] = x;
    buf [4] = y;
    int n = 5;
    for (unsigned i = 0; i < strlen(s); i++)  {
        buf [n++] = 0xA3;
        buf [n++] = s [i];
    byte chksm = 0;
    for (int i = 0; i < n; i++)
        chksm ^= buf [i];
    buf [n++] = chksm;
    return n;
void
dispBuf (
    byte *buf,
    int   nByte )
    char s [80];
    Serial.println (__func__);
    for (int i = 0; i < nByte; i++)  {
        sprintf (s, " %02x", buf [i]);
        Serial.print (s);
    Serial.println ();
void setup (void)
    Serial.begin (9600);
    int n = msg1 (buf, BUF_SIZE, prefix, 0x5, 0xC, "hello");
    dispBuf (buf, n);
void loop (void)
what you describe is the format of a message, not a protocol
a protocol is the sequences of messages between two (or more) endpoints allowing them to reliably exchange a set of commands or data
