sending 1 to xbee serial prints to 49????
when i push a button its supposed to send a 1 to my cordinator xbee and drive a motor forward allthough the data comes across as 49 instead of the 1 that the router sends or is supposed to send....does xbee convert to this for some reason?
suppose i should show my code as well router first...
#include <SoftwareSerial.h>
SoftwareSerial mySerial(11, 12); // RX, TX
//BUTTON PINS
const int SW1 = 8; //forward
const int SW2 = 9; //backward
const int SW3 = 3; //left
const int SW4 = 2; //right
  //SET BUTTON AS PULLUP
  pinMode(SW1, INPUT_PULLUP);
  pinMode(SW2, INPUT_PULLUP);
  pinMode(SW3, INPUT_PULLUP);
  pinMode(SW4, INPUT_PULLUP);
  //pinMode(Light, INPUT);
mySerial.begin(9600);
void loop(void)
  unsigned char i = 0;
  //Forward
  if (digitalRead(SW1) == HIGH)
    i += 1;
  //Backward
  if (digitalRead(SW2) == HIGH)
    i += 2;
  //left
  if (digitalRead(SW3) == HIGH)
    i += 4;
  //right
  if (digitalRead(SW4) == HIGH)
    i += 8;
  if(i > 0)
  mySerial.print(i);
 Serial.print(i);
#include <MotorDriver.h>
int data = 0;
const int rx_led = 42;
  //MOTOR SHIELD SET MOTOR SPEEDS
  motordriver.init();
  motordriver.setSpeed(400, MOTORB);
  motordriver.setSpeed(200, MOTORA); // steering motor
  //DATA RECIEVE INDICATOR LIGHT
  pinMode(rx_led, OUTPUT);
  digitalWrite(rx_led, LOW);
  //RECIEVER PINS
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  //BEGIN SERIAL COMMUNICATION
  if(Serial.available() > 0)
data = Serial.read();
  //DATA FROM TRANSMITTER TO DETERMINE MOVE FUNCTION
  // move forward
  if (data == 1)
    motordriver.goForward();
  //move backward
  else if (data == 2)
    motordriver.goBackward();
  //straight left turn
  else if (data == 5)
    motordriver.goLeft();
  //straight right turn
  else if (data == 9)
    motordriver.goRight();
  //back left turn
  else if (data == 6)
  //back right turn
  else if (data == 10)
   motordriver.stop();
  //SERIAL PRINT DATA RECIEVED
  delay(50);
  Serial.print("data=");
  Serial.println(data, DEC);
The char type is normally signed. Why are you using unsigned?
int data = 0;
Why are you sending a char, and receiving an int? They are not even the same size.
