I thought it would be an easy task but I am wrong! I am interested in sending two int values from Processing to Arduino, and I have the following code:
The idea is very simple. I just want to turn on the LED when the mouse is down. I know I could have just used 1 value, but I want to experiment with 2 values serial communication.....
Any help is much appreciated!
Arduino:
int led = 13;
int incomingByte1, incomingByte2;
// initialize serial communication
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
if (Serial.available() >= 2) {
incomingByte1 = Serial.read();
incomingByte2 = Serial.read();
if (incomingByte1 == 123 && incomingByte2 == 10)
{ digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led, LOW); // turn the LED on (HIGH is the voltage level)
Processing
// import the serial library
import processing.serial.*;
// create a serial port variable
Serial myPort;
void setup(){
size(300,300);
println("Available serial ports:");
println(Serial.list());
myPort = new Serial(this, Serial.list()[2], 9600);
void draw(){
int value1=123;
int value2=10;
if (mousePressed){
value2=10;
else {
value2=11;
myPort.write(value1);
myPort.write(value2);
I am not so sure how myPort.write() actually works.
as you can see in the code. I tried to write value1 and value2 in myPort. Both values1 and values2 are interget.... Did they get converted into other format when using write()? I would really appreciate it if anyone can clarify this...
Add a serialEvent callback to the Processing side, along with a call to myPort.bufferUntil() (to wait to call the callback until the \n arrives). Use print() in the serialEvent() function to echo to the Processing IDE window what came in the serial port.
If you get back "I got: 123" and "I got: 10", then the values are not converted. If you get back 5 strings ("I got: 31", etc.) then the values are converted to strings.
And you'll remember it far better then if we tell you the answer. In addition, you'll have learned something about how to debug your own programs.
