Sending a Byte using SPI in Arduino Nano
I just wanted to confirm whether the following code is correct for sending out a byte of data (only once) using the SPI library in Arduino Nano.
I am asking so because I am very new to using Arduino and am facing some issues when using this for my project.
Thanks in advance.
#include <SPI.h>
uint8_t const ssFPGA = 10;
  while (!Serial)
    ; // wait
  SPI.begin();
  pinMode( ssFPGA, OUTPUT );
    digitalWrite( ssFPGA, 0 );
    delay( 10 );
    SPI.beginTransaction( SPISettings(16000000, MSBFIRST, SPI_MODE3 ) );
         SPI.transfer(0x12);
         //SPI.transfer(0x34); // ------> for sending 2nd byte
         //SPI.transfer(0x56); // ------> for sending 3rd byte
    SPI.endTransaction();
    digitalWrite( ssFPGA, 1 );
    while(1);
Yes, this way you can send one byte to the SPI bus.
Keep in mind that you would not reach 16MHz on a Nano, no matter what you specify in the SPISettings constructor.
If you have problems with SPI it might help more if you describe your problem in a bit more detail. Provide links to the hardware you use in your project.
