Sending a Control Break using SoftwareSerial
At power up, I want to send a Control Break sequence so the receiver I am talking to will respond with it’s settings at 9600. If I declare pin 8 as the software serial TX pin but I have not used .begin yet, can I still use pin 8 for digital control until I issue the .begin?
#include <SoftwareSerial.h>
SoftwareSerial mySerial2(9, 8); // RX, TX
int cnt = 0;
int resp = 0;
String ggain;
  pinMode(8, OUTPUT);
  digitalWrite(8, HIGH);   //
  digitalWrite(8, LOW);    // send Ctrl Break
  mySerial2.begin(9600);
  mySerial2.listen();
  while(!mySerial2.available());
  ggain = mySerial2.readStringUntil('\n');
  Serial.println(ggain);
  mySerial2.begin(38400);
I don't know, you tell us, did it work?
Should be fine though.
Oops sorry, no the code above did not work…
This did :slight_smile:
  //PRODUCT,BD970;PORT,1,38400,38400,8,1,N,F;PORTSTATUS,ADJ;VERSION,4.22,2/9/11,,;COMM,DCOL,NMEA;SERIAL,1126400030;ETHIP,0.0.0.0
  mySerial2.listen();
  mySerial2.setTimeout(500);
  for (int p = 0; p < ggain.length();p++){
    if (ggain.startsWith("PRODUCT,")){
    else{
      ggain.remove(0,1);//drop a character at start of string
  //Serial.println(ggain);
  Serial.println("done");
Ctrl Break may mean something somewhere, but there is no such thing as Ctrl Break on the wire. The code that I see sends a Break on the wire.
