Sending a message with 433Mhz TX module and receive with SDR antenna
Hello,
First I apologize if i'm not very clear with my instructions, i'm trying my best with english :slightly_smiling_face:
Well, i have a study project to do before June and i've reach some problems of comprehension with my tools, i'm sendind a message with the VirtualWire library at the frequency of 433MHz (and of course with a Tx module), there is my code :
#include <VirtualWire.h>
#define TxPin 12
  pinMode(13, OUTPUT);
  pinMode(12, INPUT);
  Serial.begin(9600);    // Debugging only
  Serial.println("Setup Transmitter");
  // Initialise the IO and ISR
  vw_set_ptt_inverted(true); // Required for DR3100
  vw_setup(2000);  // Bits per sec
  const char *msg = "Bonsoir tous le monde";
  digitalWrite(13, true); // Flash a light to show transmitting
  vw_send((uint8_t *)msg, strlen(msg));
  //vw_wait_tx(); // Wait until the whole message is gone
  digitalWrite(13, false);
  delay(200);
And i have to receive the message i've send earlier with a SDR Antenna and the software URH or SDR# depends on what i prefer. But the things is that, i can send a message, because i can see the wave moving up and down at 433Mhz every 0,2 s ~.
Therefore what at receive when i decode the binary train is not at all the message i've send previously, there is what I receive with URH and what i can decode with CyberChef :slightly_smiling_face:
(I prefer to blur a part of the output, just in case whe never know..)
More informations :
I'm a beginner with Arduino and maybe the solutions can be found in the code, i'm not sure if the loop() function is really good, but it seems to work, and yes i have my Tx PIN plug in pin 12. Last thing is that i don't have an antenna in my Tx module, but i've saw that it's not necessary if i'm not to far the the Rx antenna.
So i need to completly understand why i can't receive the message i want to send, if someone could help me it would be amazing !!!
You are likely seeing an OOK modulation. On-Off modulation. Consider examining the LENGTH of the on times and the OFF times as they will represent one or MORE bits of the same value, 0 or 1. Then there will be a preamble to the message in order to synchronize the receiver.
So, you need to carefully study the EXACT protocol of the sending transmitter. The original message may be encoded someway before it is transmitted.
My best advice is to use a receiving module that will show you the received text of the message then you can compare that to the SDR received message.
Good luck.
So after having some test with a second arduino uno and a Rx module, i can receive in the Arduino output the message i've send previously :
Have you any idea to why i can't receive properly the message in the URH tools ?
If Arduino encode the message i can send, how can i decode it to show my message ?
Here's my code :
