Sending a remote code through IR
Hello I have been having trouble, probably because I am a noob lol I simply would like to send and ir code through my ir led. So lets say that way I can turn a tv off and on. Could someone please give me an example. :-[
a google search for: arduino ir tv brings up a lot of links that may be of use.
Also be sure to check this guy out:
http://www.tvbgone.com/cfe_tvbg_main.php
Would it be a line like this?
digitalWrite(irled, youcode here);
No, I'm sorry, it's a bit more complicated than that. "yourcode here" can, in reality, take only one of two values, HIGH or LOW.
To send a code, you have to send a stream of carefully timed HIGHs and LOWs, and even that is probably an over-simplification. Depending on the remote mfr, the HIGHs could be a short stream of even shorter pulses (modulation).
Sorry, you've got some reading to do. Good news is, there's lots of help and software out there.
Well why is it that I can go to my local radioshack and buy a remote, then I can program the code that is for my tv into it. I dont need to measures pulses lol.
Because someone else has already taken the trouble to program the microcontroller in the RadioShack remote to replay stored codes.
:o
Lawl.
Well, I’ve got the 38 KHZ Receiver(http://www.radioshack.com/product/index.jsp?productId=2049727) to work with a sample code I found online… And I understand it’s coded for a different remote, so I always get a button 0 Response, but also I get the values in.
I did a search and seen lots of receivers, even some transmitters, but I don’t understand how to implement the values I get in from Serial.print, into a IR Transmitter code.
I kind of understand the values coming in… they’re the microsecond pulses ( I think, lol ), just setting the IR pin high for that amount of time, then low, then the next value… but putting that in code is what’s confusing :smiley:
Any help understanding, or a point in the right direction would be awesome! (I hope I posted in the right area, wasn’t sure if I should start a new thread)
(PS, I’m assuming I can use the Emitter from the Radioshack Emitter/Detector pair, that’s what I’m aiming for, if not let me know please!) (http://www.radioshack.com/product/index.jsp?productId=2049723
Here’s the sample code that I’m using.
int ir_pin = 7;                         //Sensor pin 1 wired through a 220 ohm resistor
int led_pin = 13;                           //"Ready to Receive" flag, not needed but nice
int debug = 1;                           //Serial connection must be started to debug
int start_bit = 2000;                   //Start bit threshold (Microseconds)
int bin_1 = 1000;                           //Binary 1 threshold (Microseconds)
int bin_0 = 400;                             //Binary 0 threshold (Microseconds)
 pinMode(led_pin, OUTPUT);             //This shows when we're ready to receive
 pinMode(ir_pin, INPUT);
 digitalWrite(led_pin, LOW);       //not ready yet
 int key = getIRKey();             //Fetch the key
 if (key != -1) {
   Serial.print("Key Recieved: ");
   Serial.println(key);
int getIRKey() {
 int data[12];
 digitalWrite(led_pin, HIGH);     //Ok, i'm ready to recieve
 while(pulseIn(ir_pin, LOW) < 2200) { //Wait for a start bit
 data[0] = pulseIn(ir_pin, LOW);       //Start measuring bits, I only want low pulses
 data[1] = pulseIn(ir_pin, LOW);
 data[2] = pulseIn(ir_pin, LOW);
 data[3] = pulseIn(ir_pin, LOW);
 data[4] = pulseIn(ir_pin, LOW);
 data[5] = pulseIn(ir_pin, LOW);
 data[6] = pulseIn(ir_pin, LOW);
 data[7] = pulseIn(ir_pin, LOW);
 data[8] = pulseIn(ir_pin, LOW);
 data[9] = pulseIn(ir_pin, LOW);
 data[10] = pulseIn(ir_pin, LOW);
 data[11] = pulseIn(ir_pin, LOW);
 if(debug == 1) {
   Serial.println("-----");
 for(int i=0;i<=11;i++) {                 //Parse them
   if (debug == 1) {
         Serial.println(data[i]);
   if(data[i] > bin_1) {                 //is it a 1?
       data[i] = 1;
   }  else {
       if(data[i] > bin_0) {           //is it a 0?
         data[i] = 0;
        data[i] = 2;                     //Flag the data as invalid; I don't know what it is!
 for(int i=0;i<=11;i++) {                 //Pre-check data for errors
   if(data[i] > 1) {
       return -1;                           //Return -1 on invalid data
 int result = 0;
 int seed = 1;
 for(int i=11;i>=0;i--) {                //Convert bits to integer
   if(data[i] == 1) {
       result += seed;
   seed = seed * 2;
 return result;                             //Return key number
It looks like your sketch is a receiver and I think the OP wants to send. You will probably be better off starting your own thread (although this one promises to provide some unintentional humour)
Doh, sorry if I didn't make it clear!-
That's just the sketch I'm using to get IR codes from my remote (hooked up to the 38KHZ Receiver through a 220ohm resistor). I'm looking to turn what I get from that sketch, into a sketch I can use to send those through a Emitter :D
I work things out in my head, and sometimes they don't come out on the keyboard as clear, my apologies :)
I have a psp program called ir shell. It uses hex codes like these http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=pronto&db=discrete&br=dishnetwork&dv=dssreceiver to control devices.
Is there a way I convert these so I can get them the pulse way? for instance 255, 136, 130, 34
I am using this code http://zovirl.com/2008/11/12/building-a-universal-remote-with-an-arduino/
Sorry if I sound like I am crazy, but I am new to this
