Sending a struct from Arduino to Raspberry pi via Ethernet
I've been trying to send a simple packet from an Arduino to a Raspberry pi. I got it working with a struct containing 2 chars, but when it's a char and an int/float I only get the first part (See the output at the bottom).
The client sends the string 'temp' to the server which creates a packet with a char value of 'A', and a float value of '3'. Then I memcpy the packet in to a buffer, and send bytes equal to the size of the packet. On the client side I memcpy the buffer back to a packet and print it to the screen.
Server side - Arduino
#include <Ethernet.h> //Load Ethernet Library
#include <EthernetUdp.h> //Load UDP Library
#include <SPI.h> //Load the SPI Library
byte mac[] = { 0x00, 0xAC, 0xBF, 0xCC, 0x02, 0x08 }; //Assign a mac address
IPAddress ip(192, 168, 1, 177); //Assign my IP adress
unsigned int localPort = 5000; //Assign a Port to talk over
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
String datReq; //String for our data
int packetSize; //Size of Packet
EthernetUDP Udp; //Define UDP Object
//TMP36 Pin Variables
int sensorPin = 0;
struct Packet {
    char val;
    float temp;
    Serial.begin(9600); //Turn on Serial Port
    Ethernet.begin(mac, ip); //Initialize Ethernet
    Udp.begin(localPort); //Initialize Udp
    delay(1500); //delay
    packetSize = Udp.parsePacket(); //Read the packetSize
    if (packetSize>0) { //Check to see if a request is present
        Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); //Reading the data request on the Udp
        String datReq(packetBuffer); //Convert packetBuffer array to string datReq
                                     //Serial.println(datReq);
        if (datReq == "temp") { //See if Red was requested
            Packet pkt;
            pkt.val = 'A';
            pkt.temp = 3;
            Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());  //Initialize Packet send
            char txBuffer[128] = { 0 };
            memcpy(txBuffer, &pkt, sizeof(Packet));
            Udp.write(txBuffer, sizeof(Packet));
            Udp.endPacket(); //Packet has been sent
        memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE);
Client side - Raspberry pi
//See Description.txt
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
#include <arpa/inet.h>
#include <iostream>
using std::cout;
using std::endl;
struct Packet{
	char val;
	float temp;
int main(void)
    int fd;
    if ((fd = socket(AF_INET, SOCK_DGRAM, 0)) < 0) {
        cout << "socket failed" << endl;
        return 1;
    struct sockaddr_in serveraddr;
    serveraddr.sin_family = AF_INET;
    serveraddr.sin_port = htons(5000);
    serveraddr.sin_addr.s_addr = inet_addr("192.168.0.25");
	for(int i = 0; i < 5; i++){
		Packet pkt;
		pkt.temp = 0;
		sendto(fd, "temp", 4, 0, (struct sockaddr *)&serveraddr, sizeof(serveraddr));
		char rxBuffer[128] = {0};
		socklen_t addr_len = sizeof(serveraddr);
		recvfrom(fd, rxBuffer, sizeof(struct Packet), 0, (sockaddr *)&serveraddr, &addr_len);
		memcpy(&pkt, rxBuffer, sizeof(struct Packet));
		cout << pkt.val << " : " << pkt.temp << endl;
    close(fd);
Output:
A : 9.24857e-44
A : 9.24857e-44
A : 9.24857e-44
A : 9.24857e-44
A : 9.24857e-44
Can someone point out the problem here please?
There is NO reason to wrap the char array in a String just so you can use == instead of strcmp().
floats on the Pi are not the same size as floats on the Arduino.
The structs on the two devices are not the same size.
Ahh the size of the struct in the Arduino is 5 bytes, the struct in the Pi is 8.
Thank you
