Hi, I am trying to send serial data from accelerometer to another device.
Here's my code :-
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <SoftwareSerial.h>
// Assign a unique ID to accelerometer
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
SoftwareSerial xbee(2, 3);
// Declare the variables for Co-ordinates
double x = 0.0;
double y = 0.0;
double z = 0.0;
xbee.begin(57600);
// Initialise the accelerometer sensor
if(!accel.begin()) {
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
// Set the range to whatever is appropriate for your project
accel.setRange(ADXL345_RANGE_16_G);
// displaySetRange(ADXL345_RANGE_8_G);
// displaySetRange(ADXL345_RANGE_4_G);
// displaySetRange(ADXL345_RANGE_2_G);
sensors_event_t event;
accel.getEvent(&event);
xbee.write(event);
On the other side. I use something like : -
// some code
event = xbee.read()
x = event.acceleration.x;
y = event.acceleration.y;
z = event.acceleration.z;
But It seems I cannot send the struct 'event' using xbee.write. ? Is there any work around?
Either send the component elements of event one at a time - e.g. xbee.write(event.acceleration.x) (assuming I have guessed the content correctly). By the way I'm not sure if xbee.write() is limited to sending bytes and if so the elements of the struct would all need to be bytes.
OR use a Union to create a byte array that maps to the same data space as the struct and send the bytes using xbee.write(). The receiving code will need to know how to reconstruct the bytes into the struct.
Perhaps you should look at just exactly what this code is doing. There are two overloads for write() - one for arrays and one for other than arrays. Exactly which overload are you using, and how many bytes are you sending?
Until you KNOW that, or force the compiler to generate code where you can KNOW the answers, you are just stabbing in the dark as far as reading the data on the other end. Be careful of your foot when you are stabbing in the dark.
It looks like x is a double (float in reality) and will throw a compilation error.
write sends a single byte, an array of bytes of specified size or a string. So if you want to send a four byte float, you will have to send them byte by byte by some means.
On the receiving side, read returns a single byte at a time so you will need to reassemble those bytes manually into a float there.
Note also that serial data is slow - the receiving side must use serial.available before each read to verify that there is actually something in the buffer to read.
Your best bet is probably to send the struct as a whole and reassemble it on the receiver.
That won't work between arduino and PC different packing of the struct and differnt sizes of vars..
Mark
Good point on packing and var sizes - endian issues may occur too if you're talking to a device with different characteristics (doesn't look like it here). But what does it matter as long as the receiving code knows this? It just makes the reassembly more complex.
