Sending a switch signal between two arduino nano 33 BLE's
Hi guys! I am trying to send a simple switch signal from one arduino nano 33 BLE to the other one to activate a voice recording module externally. The module I am using is a ISD1820. When i have the module and the switch connected to the same arduino it works fine but as soon as i try to move it off to the other breadboard it sends no signal. I am quite new to Arduino so could someone please help me to figure out if there is a possible error in my code that could be causing this? Thank you so much in advance!
This is the central code:
#include <ArduinoBLE.h>
// Variables for sensors
const int sensorPin1 = A0;
const int sensorPin2 = A1;
const int buttonPin = 2;
int oldButtonState = LOW;
// Distance constants for sensor calibration
const int sensorReadingAt10cm = 730;
const int sensorReadingAt30cm = 220;
// Distance thresholds for motor control
const int motorThreshold1Low = 10;  // Lower distance threshold for motor 1 (cm)
const int motorThreshold1High = 20; // Higher distance threshold for motor 1 (cm)
const int motorThreshold2Low = 20;  // Lower distance threshold for motor 2 (cm)
const int motorThreshold2High = 30; // Higher distance threshold for motor 2 (cm)
BLEDevice peripheral; // Declare BLE peripheral device
  while (!Serial);
  pinMode(buttonPin, INPUT);
  BLE.begin();
  Serial.println("Bluetooth® Low Energy Central - Distance Sensor");
  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214"); // Start scanning for peripherals
  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1215"); // Start scanning for peripherals
  peripheral = BLE.available(); // Check if a peripheral has been discovered
  if (peripheral) {
    Serial.print("Found ");
    Serial.print(peripheral.address());
    Serial.print(" '");
    Serial.print(peripheral.localName());
    Serial.print("' ");
    Serial.print(peripheral.advertisedServiceUuid());
    if (peripheral.localName() != "motor") {
      return;
    BLE.stopScan(); // Stop scanning
    controlMotors(); // Control motors based on sensor readings
    BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214"); // Start scanning again
    BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1215"); // Start scanning again
void controlMotors() {
  // Connect to the peripheral
  Serial.println("Connecting ...");
  if (peripheral.connect()) {
    Serial.println("Connected");
    Serial.println("Failed to connect!");
    return;
  // Discover peripheral attributes
  Serial.println("Discovering attributes ...");
  if (!peripheral.discoverAttributes()) {
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
  // Retrieve motor characteristics
  BLECharacteristic motorCharacteristic1 = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1214");
  BLECharacteristic motorCharacteristic2 = peripheral.characteristic("19b10002-e8f2-537e-4f6c-d104768a1214");
  BLECharacteristic speakerCharacteristic = peripheral.characteristic("19b10003-e8f2-537e-4f6c-d104768a1215");
  if (!motorCharacteristic1 || !motorCharacteristic2 || !motorCharacteristic1.canWrite() || !motorCharacteristic2.canWrite()) {
    Serial.println("Peripheral does not have the required motor characteristics!");
    return;
  if (!speakerCharacteristic) {
    Serial.println("Peripheral does not have speaker characteristic!");
    return;
  } else if (!speakerCharacteristic.canWrite()) {
    Serial.println("Peripheral does not have a writable speaker characteristic!");
    return;
  while (peripheral.connected()) {
    // Read distance values from sensors
    int distanceValue1 = analogRead(sensorPin1);
    int distanceValue2 = analogRead(sensorPin2);
    // Convert sensor readings to distances (cm)
    int distanceInCm1 = map(distanceValue1, sensorReadingAt10cm, sensorReadingAt30cm, 10, 30);
    int distanceInCm2 = map(distanceValue2, sensorReadingAt10cm, sensorReadingAt30cm, 10, 30);
    Serial.print("Distance Sensor 1: ");
    Serial.print(distanceInCm1);
    Serial.println(" cm");
    Serial.print("Distance Sensor 2: ");
    Serial.print(distanceInCm2);
    // Control motor 1
    if (distanceInCm1 > motorThreshold1Low && distanceInCm1 <= motorThreshold1High) {
      motorCharacteristic1.writeValue((byte)250); // Turn motor 1 on at PWM 200
    } else if (distanceInCm1 > motorThreshold2Low && distanceInCm1 <= motorThreshold2High) {
      motorCharacteristic1.writeValue((byte)190); // Turn motor 1 on at PWM 130
      motorCharacteristic1.writeValue((byte)0); // Turn motor 1 off
    // Control motor 2
    if (distanceInCm2 > motorThreshold1Low && distanceInCm2 <= motorThreshold1High) {
      motorCharacteristic2.writeValue((byte)250); // Turn motor 2 on at PWM 200
    } else if (distanceInCm2 > motorThreshold2Low && distanceInCm2 <= motorThreshold2High) {
      motorCharacteristic2.writeValue((byte)190); // Turn motor 2 on at PWM 130
      motorCharacteristic2.writeValue((byte)0); // Turn motor 2 off
    delay(1000); // Delay before next sensor readings
    int buttonState = digitalRead(buttonPin);
  if (oldButtonState != buttonState) {
      // button changed
      oldButtonState = buttonState;
      if (buttonState) {
        Serial.println("button pressed");
        // button is pressed, write 0x01 to turn the speaker on
        speakerCharacteristic.writeValue((byte)0x01);
        Serial.println("button released");
        // button is released, write 0x00 to turn the speaker off
        speakerCharacteristic.writeValue((byte)0x00);
And this is the peripheral code:
BLEService motorService("19B10000-E8F2-537E-4F6C-D104768A1214"); // Bluetooth® Low Energy motor service
BLEService speakerService("19B10000-E8F2-537E-4F6C-D104768A1215");
BLEByteCharacteristic pwmCharacteristic1("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite); // PWM characteristic for motor 1
BLEByteCharacteristic pwmCharacteristic2("19B10002-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite); // PWM characteristic for motor 2
BLEByteCharacteristic switchCharacteristic("19B10003-E8F2-537E-4F6C-D104768A1215", BLERead | BLEWrite); // Switch characteristic
const int motorPin1 = 2; // pin for motor 1
const int motorPin2 = 4; // pin for motor 2
const int speakerPin1 = 6; // pin for speaker 1
const int speakerPin2 = 7; // pin for speaker 2
  while (!Serial);
  pinMode(motorPin1, OUTPUT); // set motor pin to output mode
  pinMode(motorPin2, OUTPUT);
  pinMode(speakerPin1, OUTPUT); // set speaker pin to output mode
  pinMode(speakerPin2, OUTPUT);
  if (!BLE.begin()) {
    Serial.println("Starting Bluetooth® Low Energy module failed!");
    while (1);
  BLE.setLocalName("motor");
  BLE.setAdvertisedService(motorService);
  BLE.setAdvertisedService(speakerService);
  motorService.addCharacteristic(pwmCharacteristic1);
  motorService.addCharacteristic(pwmCharacteristic2);
  speakerService.addCharacteristic(switchCharacteristic);
  BLE.addService(motorService);
  BLE.addService(speakerService);
  pwmCharacteristic1.writeValue(0); // Set initial PWM value to 0
  pwmCharacteristic2.writeValue(0);
  switchCharacteristic.writeValue(0);
  BLE.advertise();
  Serial.println("BLE motor Peripheral");
  BLEDevice central = BLE.central();
  if (central) {
    Serial.print("Connected to central: ");
    Serial.println(central.address());
    while (central.connected()) {
      if (pwmCharacteristic1.written()) {
        int pwmValue1 = pwmCharacteristic1.value();
        Serial.print("PWM value for motor 1: ");
        Serial.println(pwmValue1);
        analogWrite(motorPin1, pwmValue1); // Write PWM value to motor 1 pin
      if (pwmCharacteristic2.written()) {
        int pwmValue2 = pwmCharacteristic2.value();
        Serial.print("PWM value for motor 2: ");
        Serial.println(pwmValue2);
        analogWrite(motorPin2, pwmValue2); // Write PWM value to motor 2 pin
      if (switchCharacteristic.written()) {
        if (switchCharacteristic.value()) {   // any value other than 0
        Serial.println("Switch characteristic written!");
          Serial.println("speaker on");
          digitalWrite(speakerPin1, HIGH);
           digitalWrite(speakerPin2, HIGH);         // will turn the LED on
        } else {                              // a 0 value
          Serial.println(F("speaker off"));
          digitalWrite(speakerPin1, LOW);
          digitalWrite(speakerPin2, LOW);             // will turn the LED off
    // when the central disconnects, print it out:
    Serial.print(F("Disconnected from central: "));
the posted code is using Bluetooth
i don't seeing code to pass a signal between to processors
the two arduinos are communicating through bluetooth
have you tried a simple program that just sends and received text strings?
Yes I have. I have tested the switch signal being sent to the speakers on its own and it works. But when i input it into the code with the sensors it does not work
can you be more specific about which of your programs is monitoring a sensor, which sensor, where in the code your monitoring the sensor and where you send the bluetooth string
The code to write the button value is outside of the while(peripheral.connected) block.
    // Control motor 1
    // Control motor 2
Are you indeed seeing the "button pressed" and "button released" serial prints?
