Sending a value between Arduinos using HC-05 Bluetooth modules
Good catch! Switched those wires so TX goes to RX and RX to TX but unfortunately nothing changed.
I would change all the .write() statements to .print() just to be sure that what is being sent is printable.
I don’t have two modules set up, but I tested the servant (default state for HC05) program with a phone as a master, and it worked as planned when sent 12 from the phone.
When I place the sketches on two different Arduino unos without bluetooth and jumper/cross connect pins 2 and 3 on both units, the two codes communicate as planned.
I would put your focus on the master program. Are you certain the conversion from the default state was done correctly? How does the master connect to the servant module? How do you know the two modules are connected?
The LED on the HC05 modules have specific flashes to tell what mode that it is in.
AT mode alternating ≈3 seconds on and ≈3 seconds off.
Not connected rapid flashing ≈2 Hz.
Connected 2 rapid flashes followed by off for ≈3 seconds.
If they are connected, both modules should show the 2 rapid flashes with the longer off time. Not necessarily in sync.
I set up 2 more HC-05’s and tried them on the circuit too, but the outcome was the same.
The LEDs switch to the long pause followed by 2 rapid blinks pattern shortly after they’re turned on. I have them on CMODE=0, so that should mean they’re pairing with each other. I set them up while they were in AT mode (long blinks, long pauses).
Could it be an issue with the HC-05’s? I’ve ordered some more from a different brand, so I’ll try those out once they arrive
Thank you so much for verifying the code! I appreciate it :slight_smile:
I used this page to set my 2 HC05 modules up to talk to each other. I set the master to role=1 and the slave to role=0. Using the instructions from the linked page, my HC05s automatically paired and connected right away.
That page is a good reference.
@cattledog @groundFungus
Idk how pings are used here, but the thread was dead for a while due to finals and graduation and now I'm back! I bought 2 more modules and set them up using Fungus's link. Everything was the same as in my initial setup except now I know how to check the baud rate in AT command mode! :slight_smile: No matter how I held the reset button while powering the module on, they would not enter AT command mode so I resorted to setting their baud rate to 38400 manually, then resetting it to 9600.
The result was the same issue as before: 12 is printed on the master module's serial monitor, servant receives nothing.
I noticed that the example in Fungus's link used 38400 baud rate all the time (and also did not use softwareserial)... but since I've got RF using our serial port too I don't think I can just do that. So everything was reset to 9600 before my tests.
I'm so baffled by this whole thing
Did you change the Serial.write() to Serial.print() as suggested in reply #7.
Please post images of your screen shots of the AT dialog for the configuration of the master and slave.
These are the images shown in the tutorial, but your address and perhpas baud rate will be different
I tried serial.write, then switched to serial.print
Here's the screenshot of the serial monitor for the servant module. I would use AT+UART=9600,0,0 to set it back before testing, cause the codes are still set to 9600
Here's master module
Can you explain more about this. The changing of baud rate to say you are in AT mode sounds strange. What does the light blink patterns say about whether or not you are really in AT mode?
The setup screens look correct, and you say that the module flash pattern looks like they are connected.
Can you get the slave to respond if you send something to it with an Android phone terminal program. I use Kai Morich's Serial Bluetooth Terminal.
Are you testing the bluetooth piece of this project in isolation from the "alarm/activation system"? There may be power issues with trying to run two transmitters.
I think that the setting of the baud rate is AT+UART=baud,1,0. That is baud, 1 stop bit, no parity. Needs one stop bit cause Arduino serial is 8n1 (8 bit, no parity, 1 stop bit.
The HC05 has 2 AT modes. A partial mode where you can change stuff like the name. And full mode to change things like password and baud rate. See this page on putting the HC05 in full AT mode.
This page has AT commands and their syntax.
Yes, that's correct and I didn't notice. The changing around of baud rates related to the AT issues have not helped at all.
The Slave module should actually be in its default state and shouldn't require any changes unless the default baud rate is not 9600.
I hold the reset button while plugging in the uno I use for the HC-05 setup. This results in long, slow blinks.
I just used AT+NAME? to check if it's actually in full AT command mode, and it looks like I'm in full AT command regardless of the baud rate I set the devices too :smiley:
Ok, so I set the baud rate on both modules to 9600,1,0, and I'm receiving values on the receiver end!!!! I get 49, 50, 49, 50, etc etc etc. Not correct, but so so close :smiley:
edit: Ok so the modules are sending the digits one at a time and adding 48 to each digit. I'm not sure why the digits get separated.
Those are ASCII codes. That represents the characters '1','2','1','2'. If you want to see characters use Serial.println(char(bt.read())); or, like you say, subtract 48 (for characters '0' to '9' only though).
Post your new code. Always post the new code whenever there are changes so we can keep up.
With my HC05 modules I can put them into partial AT mode by holding the button when powering them up and then release the button. I can change some things but not all. To go to full AT mode I can hold the button pressed with a small alligator clip and plug the module in holding the button down all the time. That has worked for every module that I have tried. It is then in full mode and I can make any changes. The LED blinks the same whether it is in full or partial AT mode.
Thanks for your patience :slight_smile:
Interesting... so continuous holding is full AT mode? Good to know!
Here are the current codes. The receiving end now gets 1 2 1 2 1 2, etc. Ideally, I'd like to receive 12 12 12 if that's possible. I did some experimentation with storing ID as different data types, but it seems like the problem is with how the Bluetooth modules send strings of info? I saw some discussion of Serial.readString online, but I got an error when I tried to use it.
Sending/Master
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(2, 3); // RX | TX
Serial.println("Enter AT commands:");
// HC-06 default baud rate is 9600
BTSerial.begin(9600);
uint8_t ID = 12;
//int ID = 12;
//char ID = 12;
BTSerial.print(ID);  //send ID value to other Bluetooth module?
Serial.print(ID);
Receiving/Servant
SoftwareSerial BTserial(2, 3); // RX | TX
// Connect the HC-05 TX to Arduino pin 2 RX.
// Connect the HC-05 RX to Arduino pin 3 TX through a voltage divider.
uint8_t ID;
//int ID;
//char ID;
Serial.println("Arduino is ready");
Serial.println("Remember to select Both NL & CR in the serial monitor");
// HC-05 default serial speed is 9600
BTserial.begin(9600);
// Keep reading from HC-05 and send to Arduino Serial Monitor
if (BTserial.available())
    ID = BTserial.read();
// Serial.print(ID);
Serial.println(char(ID));
I recommend that you go study the serial input basics tutorial. All of the principles and methods that apply to Serial apply to software serial. Good reliable methods for receiving (and sending) data over serial ports.
Would be `
const char ID[] = "12";
to make ID a string constant.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
I also recommend the Serial Input Basics tutorial.
One other thing to review is the references to .print() and .write().
You need to pick a path for your project to send numbers as ascii data or binary numerical values. Ascii is easier to debug, binary can be faster.
For example if you want to send 12 as a byte 0x0C (B00001100) instead of as "12" you can change your sending code to
BTSerial.write(ID);
If you want to display the received byte as 12 on the monitor use
Serial.print(ID,DEC);
Oof, I misunterpreted the "general guidance" thread as saying I should use ... now that I see the </> button it seems obvious lol. I'd been wondering why I couldn't get my code looking all nice
Regardless, it works! Entirely and completely! I've included the code below and thank you both SO MUCH for your help! This weird little project went outside the knowledge base of the professor I'd been bothering, and it's so cool to me that people are so passionate about something to just help a stranger out on the forums. The only question I really need an answer to now is whether or not I can mark several responses as answers lol
char ID[] = "12";  //string constant
    BTSerial.println(ID);  //send ID value to other Bluetooth module?
    Serial.println(ID);
const byte numChars = 32;
char ID[numChars];
boolean newData = false;
    char l;
    char endMarker = '\n';
    static byte ndx = 0;
    while (BTserial.available() > 0 && newData == false) {
      l = BTserial.read();
      if (l != endMarker) {
          ID[ndx] = l;
          ndx++;
          if (ndx >= numChars) {
              ndx = numChars - 1;
          ID[ndx] = '\0'; // terminate the string
          ndx = 0;
          newData = true;
     Serial.println(ID);
