Sending a variable via RF communication
Hello Everyone!
I have trouble with a program;
I want to send a variable form one Arduino to another.
The first Arduino only sends a number [0 / 1 / 2], canged in the program itself (No imput or anything else)
The second one reads the state and turns a red or green LED on or off.
[0= red off, green off / 1= red on, green off / 2= red off, green one]
I have found a tutorial, but i don´t understand the “Split data” part.
I don´t need it, but it seems to be nessesary for the code to work.
my actual state:
transmitter:
#include <VirtualWire.h>
int var = 1;
char CharMsg[21];// The string that we are going to send trought rf
  // VirtualWire setup
  vw_set_ptt_inverted(true);
  vw_setup(2000); // Bits per sec
  vw_set_tx_pin(12);// Set the Tx pin. Default is 12
  sprintf(CharMsg, "%d,%d,%d,%d,%d,%d", var);
  delay(5);
  vw_send((uint8_t *)CharMsg, strlen(CharMsg));
  vw_wait_tx(); // Wait until the whole message is gone
  delay(40);
reciever:
const int receive_pin = 12;
int maxSensorData = 6;
int recieved;
char StringReceived[22];
int LEDred = 10;
int LEDgreen = 11;
  pinMode(LEDred, OUTPUT);
  pinMode(LEDgreen, OUTPUT);
  Serial.begin(9600);                        // initialising serial
  vw_set_rx_pin(receive_pin);                // virtual wire setup
  vw_set_ptt_inverted(true);                 // virtual wire setup
  vw_setup(2000);                            // bits per second
  vw_rx_start();                             // Start the receiver PLL running
} // END void setup
void loop(){
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen)) {        //Taking the data from the control base
    int i;
    for (i = 0; i < buflen; i++) {
      StringReceived[i] = char(buf[i]);      // data to array
    // split data into array sensorData
    sscanf(StringReceived, "%d,%d,%d,%d,%d,%d", &recieved); // Converts a string to an array
  if (recieved == 1){
    digitalWrite(LEDgreen, LOW);
    digitalWrite(LEDred, HIGH);
    if (recieved == 2) {
      digitalWrite(LEDred, LOW);
      digitalWrite(LEDgreen, HIGH);
  Serial.print(recieved);
  Serial.println("");
  // reset variable StringReceived
  memset(StringReceived, 0, sizeof(StringReceived));
  delay(5);
and the link of the tutorial:
http://www.simsso.de/?type=arduino/mx-05v-mx-fs-03v
what do i wrong?
can you fix the conde and explain it to me?
Thank you very much,
Atvilar
what do i wrong?
You didn't say. What happens when you run the program?
If you will be using the function sprintf(), you should learn how it works. Start here: http://www.tutorialspoint.com/c_standard_library/c_function_sprintf.htm http://www.cplusplus.com/reference/cstdio/sprintf/
Hello,
I sorry...
Both codes are running without any decompiling problems or so, but there is no LED shining, and if i read the serial monitor on the reciever side, it only recieves "0" (nothing?).
The var on the transmitter side = 1
thanks
Atvilar
For every format specifier, you are supposed to supply a variable. 6 format specifiers means 6 variables are supposed to be listed.
Completely unnecessary.
Same problem as sprintf. The number of variables needs to match the number of format specifiers.
Fix the sender and receiver and test again.
I would recommend that you start with the simple examples providing with VirtualWire.
The very simplest just sends a character string, which is all you need for your example.
Hello,
Thanks jremington, but it is not compartible with my module(s)
Thanks PaulS, I will hav a look at it after work and report to you.
Yours
Atvilar
You [u]already using[/u] VirtualWire, just incorrectly.
