sending a varint over Ethernet
I am attempting a small cut back minecraft server and need to be able to send a varint.
Varints can be found here developers.Google.com/protocol-buffers/docs/encoding
I need to be able to send them through the Ethernet library
Thanks :) Robert
They can’t, however, be found on the Arduino.
And, your “link” doesn’t work.
I fail to see where i write the word 'link'.
Can I send BITS using the Ethernet library?
You didn't. You posted this useless statement:
That is not a link or anything that is useful.
Of course you can. As a matter of fact, that is ALL that you can send. 8 of them at a time.
I don't see whats wrong with it - I've copy pasted it into 2 browsers and it works fine?
Sorry what I mean is can I decide the individual bits that are sent easily?
So for example
Client.print((bin)00101100)
Thanks for helping :)
Why should I have to do that? If the browser doesn't display the http:// bit up front, that doesn't mean it isn't required.
No. All the bits in a byte are sent. You can create a byte that has only the bits you want set.
Why are you trying to cast an octal value to bin? 0bxxxxxxxx is the correct way to define a binary value, and doesn't need any cast.
You choose to answer - it took much more effort for you to complain than it did just to copy and paste. I'm asking a question, and if I get something wrong it would be nice if you just told me and not made an arrogant comment.
I've asked in a c++ forum and people there have explained it - but thank you for trying.
