Hello, I'm working on a project which has multiple ultrasonic sensors. With D0-D1 I'm sending chars to another arduino. One is working as a slave and has all the sensors on it. The other one works as the master and drives all the motors. The problem here is that I'm sending for exemple AN and after a few milliseconds, on the master arduino I'm getting NA and 2 white blocs (No idea how to write them). Plus it seems the code creates a delay. I've been stuck on this for a whole day. I've tried a similar code which was working. But I don't understand why it doesn't work now.
the code to send the data on the slave arduino is as this :
#include <NewPing.h>
/* EC-X = Echo capteur X TC-X = Trigger capteur X
* G = gauche C = centre D = droite */
#define ECG 2
#define ECC 3
#define ECD 4
#define TCG 6
#define TCC 7
#define TCD 8
#define DISTANCE_RIEN 25
#define MAX_DISTANCE 200 //
#define POWER 12 //Switch on/off du programme
unsigned int distance_gauche, distance_droite, distance_centre;
char valeur[2];
NewPing capteur_gauche(TCG, ECG, 50);
NewPing capteur_droite(TCD, ECD, 50);
NewPing capteur_centre(TCC, ECC, 50);
Serial.begin(115200); // Starts the serial communication
pinMode(POWER,INPUT);
delay (10);
distance_gauche = capteur_gauche.ping() / US_ROUNDTRIP_CM;
distance_droite = capteur_droite.ping() / US_ROUNDTRIP_CM;
distance_centre = capteur_centre.ping() / US_ROUNDTRIP_CM;
/* Envoi en uart de données sur le second arduino:
* G = Gauche, D = Droite, C = Centre (mur), A = Avance */
// DISTANCE GAUCHE ONLY
if((distance_gauche > 0 && distance_gauche < DISTANCE_RIEN)&&(distance_droite == 0 || distance_droite > DISTANCE_RIEN)){
valeur[0] = 'G';
// DISTANCE DROITE ONLY
if((distance_droite > 0 && distance_droite < DISTANCE_RIEN)&&(distance_gauche == 0 || distance_gauche > DISTANCE_RIEN)){
valeur[0] = 'D';
// DISTANCE MUR
if((distance_droite > 0 && distance_droite <= DISTANCE_RIEN)&&(distance_gauche > 0 && distance_gauche <= DISTANCE_RIEN)){
valeur[0] = 'M';
// DETECTE RIEN
if((distance_droite == 0 || distance_droite > DISTANCE_RIEN)&&(distance_gauche == 0 || distance_gauche > DISTANCE_RIEN)){
valeur[0] = 'A';
// DETECTION DU CAPTEUR DU MILIEU
/* Si le capteur détecte qqch c'est un obstacle donc il envoie Y car il detecte qqch
* Si le capteur détecte rien c'est qu'il n'y a pas d'obstacle donc il renvoie N
if(distance_centre != 0){
valeur[1] = 'Y';
valeur[1] = 'N';
Serial.write(valeur,2);
and the code for the main arduino is this :
#include <Servo.h>
/* Le moteur de droite est le A, gauche le B
si (IN1,H / IN2,L) si (IN3,H / IN4,l) alors
le robot va tout droit */
#define IN1 9 // commande demi-pont 1 (A) sur broche 9
#define IN2 10 // commande demi-pont 2 (A) sur broche 10
#define IN3 12 // commande demi-pont 3 (B) sur broche 12
#define IN4 13 // commande demi-pont 4 (B) sur broche 13
#define G1 6 // commande transistor 1 sur broche 6
#define G2 7 // commande transistor 2 sur broche 7
#define ENA 3 // validation pont A sur broche 3
#define ENB 5 // validation pont B sur broche 5
#define VMAX_A 100
#define VROTA_A 110
#define V50_A 80
#define VMAX_B 120
#define VROTA_B 135
#define V50_B 90
#define OFF 0
Servo monServomoteur;
bool AVANCER = true;
int angle_rotation, compteur_avance, pause_avance, pos = 0;
char etat[2];
char flag_avance, moteur, tourelle;
long current_time, start_time;
pinMode(ENA, OUTPUT); // sets the pin as output
pinMode(ENB, OUTPUT); // sets the pin as output
pinMode(G1, OUTPUT); // sets the pin as output
pinMode(G2, OUTPUT); // sets the pin as output
pinMode(IN1, OUTPUT); // sets the pin as output
pinMode(IN2, OUTPUT); // sets the pin as output
pinMode(IN3, OUTPUT); // sets the pin as output
pinMode(IN4, OUTPUT); // sets the pin as output
digitalWrite(G2, LOW); // relais 2 OFF
digitalWrite(G1, LOW); // relais 1 OFF
analogWrite(ENA, 0); // arrĂȘt du moteur A
analogWrite(ENB, 0); // arrĂȘt du moteur B
monServomoteur.attach(10);
current_time = millis();
start_time = current_time;
/* Lecture de l'état affilié à la course en fonction des capteurs
A = avance tout droit (si pas de capteurs detectent)
G = tourne Ă gauche (seulement si capteur droite detecte)
D = tourne Ă droite (seulement si capteur gauche detecte)
M = mur final (si les deux capteurs detectent)
delay(50);
if(Serial.available()){
Serial.readBytes(etat,2);
/* Serial.print("Etat Ă : ");*/
moteur = etat[0];
tourelle = etat[1];
Serial.print(moteur);
Serial.println(tourelle);
/* Serial.print(" et angle de : ");
Serial.println(angle_rotation);*/
if((etat[0] == 'A')&&(flag_avance >= 3)){
//VERIFICATION DE LA ROTATION
if (angle_rotation != 0) {
//SI PAS ENCORE AVANCE POUR QUITTER L'ANGLE
if (AVANCER) {
if(flag_avance >= 17){
flag_avance = 0;
AVANCER = false;
else{
avance(VMAX_A,VMAX_B);
flag_avance ++;
//TOURNE A DROITE
if ((angle_rotation < 0)&&(AVANCER == false)) {
tourne_droite();
if(angle_rotation == 0)
flag_avance = 0;
//TOURNE A GAUCHE
if ((angle_rotation > 0)&&(AVANCER == false)) {
tourne_gauche();
flag_avance = 0;
else{
AVANCER = true;
else{
if(etat[0] == 'A')
flag_avance++;
// ETAT D ---------------------------------------------------------
if(etat[0] == 'D'){
//TOURNE A DROITE
tourne_droite();
flag_avance = 0;
AVANCER = true;
// ETAT G ---------------------------------------------------------
if(etat[0] == 'G'){
//TOURNE A GAUCHE
tourne_gauche();
flag_avance = 0;
AVANCER = true;
// ETAT M ---------------------------------------------------------
if(etat[0] == 'M'){
for (pos = 0; pos <= 180; pos += 1) {
monServomoteur.write(pos);
if(etat[0] == 'H'){
for (pos = pos; pos <= pos - 10; pos -= 1){
int pause() {
digitalWrite(IN1, LOW); // moteur A tourne dans sens -
digitalWrite(IN2, LOW);
digitalWrite(ENA,OFF);
digitalWrite(IN3, LOW); // moteur A tourne dans sens -
digitalWrite(IN4, LOW);
digitalWrite(ENB,OFF);
int tourne_droite() {
digitalWrite(IN1, HIGH); // moteur A tourne dans sens -
analogWrite(ENA, VROTA_A); // moteur A vitesse 1/2
digitalWrite(IN3, HIGH); // moteur A tourne dans sens -
analogWrite(ENB, VROTA_B); // moteur A vitesse 1/2
angle_rotation += 1;
int tourne_gauche() {
digitalWrite(IN2, HIGH);
digitalWrite(IN4, HIGH);
angle_rotation -= 1;
int avance(int vitesse_A,int vitesse_B ) {
analogWrite(ENA, vitesse_A); // moteur A vitesse 1/2
analogWrite(ENB, vitesse_B); // moteur A vitesse 1/2
