Sending an int = 1 from quest 2 to an esp32 through Bluetooth serialport is not working
So, I am trying to send an int = 1 from Oculus quest 2 to an esp32 aruindo if I move the thumbstick in the vr environment. For some reason, it is not doing anything. I am not getting any error. So, I honestly am not sure what I am doing wrong. The serial port command I used does open up the port. Here is the unity script I used https://pastebin.com/9pWGY5aJ and this is the esp32 script that should be able to read the data https://pastebin.com/qCFZg415. Thanks for any help. Edit: So, I think I figure out why it is not working. I dont believe you can initiliaze the port using this command public static SerialPort sp = new SerialPort("COM4", 115200); for android because that what the quest 2 through unity uses to sideload apps. Anyone know a method I can use to initalize the serial port for android in c#. Final edit: I figured it out.
Unity code
using System;
using UnityEngine;
using System.IO.Ports;
using System.Threading;
/// <summary>
/// Controls the player's movement in virtual reality.
/// </summary>
[RequireComponent(typeof(CharacterController))]
public class OVRPlayerController : MonoBehaviour
	public static SerialPort sp = new SerialPort("COM4", 115200); //initialize the port
	int x = 1; //testing data to send
	/// <summary>
	/// The rate acceleration during movement.
	/// </summary>
	public float Acceleration = 0.1f;
	/// <summary>
	/// The rate of damping on movement.
	/// </summary>
	public float Damping = 0.3f;
	/// <summary>
	/// The rate of additional damping when moving sideways or backwards.
	/// </summary>
	public float BackAndSideDampen = 0.5f;
	/// <summary>
	/// The force applied to the character when jumping.
	/// </summary>
	public float JumpForce = 0.3f;
	/// <summary>
	/// The rate of rotation when using a gamepad.
	/// </summary>
	public float RotationAmount = 1.5f;
	/// <summary>
	/// The rate of rotation when using the keyboard.
	/// </summary>
	public float RotationRatchet = 45.0f;
	/// <summary>
	/// The player will rotate in fixed steps if Snap Rotation is enabled.
	/// </summary>
	[Tooltip("The player will rotate in fixed steps if Snap Rotation is enabled.")]
	public bool SnapRotation = true;
	/// <summary>
	/// How many fixed speeds to use with linear movement? 0=linear control
	/// </summary>
	[Tooltip("How many fixed speeds to use with linear movement? 0=linear control")]
	public int FixedSpeedSteps;
	/// <summary>
	/// If true, reset the initial yaw of the player controller when the Hmd pose is recentered.
	/// </summary>
	public bool HmdResetsY = true;
	/// <summary>
	/// If true, tracking data from a child OVRCameraRig will update the direction of movement.
	/// </summary>
	public bool HmdRotatesY = true;
	/// <summary>
	/// Modifies the strength of gravity.
	/// </summary>
	public float GravityModifier = 0.379f;
	/// <summary>
	/// If true, each OVRPlayerController will use the player's physical height.
	/// </summary>
	public bool useProfileData = true;
	/// <summary>
	/// The CameraHeight is the actual height of the HMD and can be used to adjust the height of the character controller, which will affect the
	/// ability of the character to move into areas with a low ceiling.
	/// </summary>
	[NonSerialized]
	public float CameraHeight;
	/// <summary>
	/// This event is raised after the character controller is moved. This is used by the OVRAvatarLocomotion script to keep the avatar transform synchronized
	/// with the OVRPlayerController.
	/// </summary>
	public event Action<Transform> TransformUpdated;
	/// <summary>
	/// This bool is set to true whenever the player controller has been teleported. It is reset after every frame. Some systems, such as
	/// CharacterCameraConstraint, test this boolean in order to disable logic that moves the character controller immediately
	/// following the teleport.
	/// </summary>
	[NonSerialized] // This doesn't need to be visible in the inspector.
	public bool Teleported;
	/// <summary>
	/// This event is raised immediately after the camera transform has been updated, but before movement is updated.
	/// </summary>
	public event Action CameraUpdated;
	/// <summary>
	/// This event is raised right before the character controller is actually moved in order to provide other systems the opportunity to
	/// move the character controller in response to things other than user input, such as movement of the HMD. See CharacterCameraConstraint.cs
	/// for an example of this.
	/// </summary>
	public event Action PreCharacterMove;
	/// <summary>
	/// When true, user input will be applied to linear movement. Set this to false whenever the player controller needs to ignore input for
	/// linear movement.
	/// </summary>
	public bool EnableLinearMovement = true;
	/// <summary>
	/// When true, user input will be applied to rotation. Set this to false whenever the player controller needs to ignore input for rotation.
	/// </summary>
	public bool EnableRotation = true;
	/// <summary>
	/// Rotation defaults to secondary thumbstick. You can allow either here. Note that this won't behave well if EnableLinearMovement is true.
	/// </summary>
	public bool RotationEitherThumbstick = false;
	protected CharacterController Controller = null;
	protected OVRCameraRig CameraRig = null;
	private float MoveScale = 1.0f;
	private Vector3 MoveThrottle = Vector3.zero;
	private float FallSpeed = 0.0f;
	private OVRPose? InitialPose;
	public float InitialYRotation { get; private set; }
	private float MoveScaleMultiplier = 1.0f;
	private float RotationScaleMultiplier = 1.0f;
	private bool SkipMouseRotation = true; // It is rare to want to use mouse movement in VR, so ignore the mouse by default.
	private bool HaltUpdateMovement = false;
	private bool prevHatLeft = false;
	private bool prevHatRight = false;
	private float SimulationRate = 60f;
	private float buttonRotation = 0f;
	private bool ReadyToSnapTurn; // Set to true when a snap turn has occurred, code requires one frame of centered thumbstick to enable another snap turn.
	private bool playerControllerEnabled = false;
	void Start()
		OpenConnection(); //start up the connection
		// Add eye-depth as a camera offset from the player controller
		var p = CameraRig.transform.localPosition;
		p.z = OVRManager.profile.eyeDepth;
		CameraRig.transform.localPosition = p;
	void Awake()
		Controller = gameObject.GetComponent<CharacterController>();
		if (Controller == null)
			Debug.LogWarning("OVRPlayerController: No CharacterController attached.");
		// We use OVRCameraRig to set rotations to cameras,
		// and to be influenced by rotation
		OVRCameraRig[] CameraRigs = gameObject.GetComponentsInChildren<OVRCameraRig>();
		if (CameraRigs.Length == 0)
			Debug.LogWarning("OVRPlayerController: No OVRCameraRig attached.");
		else if (CameraRigs.Length > 1)
			Debug.LogWarning("OVRPlayerController: More then 1 OVRCameraRig attached.");
			CameraRig = CameraRigs[0];
		InitialYRotation = transform.rotation.eulerAngles.y;
	void OnEnable()
	void OnDisable()
		if (playerControllerEnabled)
			OVRManager.display.RecenteredPose -= ResetOrientation;
			if (CameraRig != null)
				CameraRig.UpdatedAnchors -= UpdateTransform;
	void Update()
		if (OVRInput.Get(OVRInput.Touch.PrimaryIndexTrigger)) //detect input
			sp.Write(x.ToString()); //send value
		if (!playerControllerEnabled)
			if (OVRManager.OVRManagerinitialized)
				OVRManager.display.RecenteredPose += ResetOrientation;
					CameraRig.UpdatedAnchors += UpdateTransform;
				playerControllerEnabled = true;
				return;
		if (Input.GetKeyDown(KeyCode.Q))
			buttonRotation -= RotationRatchet;
		if (Input.GetKeyDown(KeyCode.E))
			buttonRotation += RotationRatchet;
	public void OpenConnection()
		if (sp != null)
			if (sp.IsOpen)
				sp.Close();
				print("Closing port, because it was already open!");
				sp.Open();  // opens the connection
				sp.ReadTimeout = 16;  // sets the timeout value before reporting error
				print("Port Opened!");
			if (sp.IsOpen)
				print("Port is already open");
				print("Port == null");
	void OnApplicationQuit()
		sp.Close();
	protected virtual void UpdateController()
		if (useProfileData)
			if (InitialPose == null)
				// Save the initial pose so it can be recovered if useProfileData
				// is turned off later.
				InitialPose = new OVRPose()
					position = CameraRig.transform.localPosition,
					orientation = CameraRig.transform.localRotation
			if (OVRManager.instance.trackingOriginType == OVRManager.TrackingOrigin.EyeLevel)
				p.y = OVRManager.profile.eyeHeight - (0.5f * Controller.height) + Controller.center.y;
			else if (OVRManager.instance.trackingOriginType == OVRManager.TrackingOrigin.FloorLevel)
				p.y = -(0.5f * Controller.height) + Controller.center.y;
		else if (InitialPose != null)
			// Return to the initial pose if useProfileData was turned off at runtime
			CameraRig.transform.localPosition = InitialPose.Value.position;
			CameraRig.transform.localRotation = InitialPose.Value.orientation;
			InitialPose = null;
		CameraHeight = CameraRig.centerEyeAnchor.localPosition.y;
		if (CameraUpdated != null)
			CameraUpdated();
		UpdateMovement();
		Vector3 moveDirection = Vector3.zero;
		float motorDamp = (1.0f + (Damping * SimulationRate * Time.deltaTime));
		MoveThrottle.x /= motorDamp;
		MoveThrottle.y = (MoveThrottle.y > 0.0f) ? (MoveThrottle.y / motorDamp) : MoveThrottle.y;
		MoveThrottle.z /= motorDamp;
		moveDirection += MoveThrottle * SimulationRate * Time.deltaTime;
		// Gravity
		if (Controller.isGrounded && FallSpeed <= 0)
			FallSpeed = ((Physics.gravity.y * (GravityModifier * 0.002f)));
			FallSpeed += ((Physics.gravity.y * (GravityModifier * 0.002f)) * SimulationRate * Time.deltaTime);
		moveDirection.y += FallSpeed * SimulationRate * Time.deltaTime;
		if (Controller.isGrounded && MoveThrottle.y <= transform.lossyScale.y * 0.001f)
			// Offset correction for uneven ground
			float bumpUpOffset = Mathf.Max(Controller.stepOffset, new Vector3(moveDirection.x, 0, moveDirection.z).magnitude);
			moveDirection -= bumpUpOffset * Vector3.up;
		if (PreCharacterMove != null)
			PreCharacterMove();
			Teleported = false;
		Vector3 predictedXZ = Vector3.Scale((Controller.transform.localPosition + moveDirection), new Vector3(1, 0, 1));
		// Move contoller
		Controller.Move(moveDirection);
		Vector3 actualXZ = Vector3.Scale(Controller.transform.localPosition, new Vector3(1, 0, 1));
		if (predictedXZ != actualXZ)
			MoveThrottle += (actualXZ - predictedXZ) / (SimulationRate * Time.deltaTime);
	public virtual void UpdateMovement()
		if (HaltUpdateMovement)
			return;
		if (EnableLinearMovement)
			bool moveForward = Input.GetKey(KeyCode.W) || Input.GetKey(KeyCode.UpArrow);
			bool moveLeft = Input.GetKey(KeyCode.A) || Input.GetKey(KeyCode.LeftArrow);
			bool moveRight = Input.GetKey(KeyCode.D) || Input.GetKey(KeyCode.RightArrow);
			bool moveBack = Input.GetKey(KeyCode.S) || Input.GetKey(KeyCode.DownArrow);
			bool dpad_move = false;
			if (OVRInput.Get(OVRInput.Button.DpadUp))
				moveForward = true;
				dpad_move = true;
			if (OVRInput.Get(OVRInput.Button.DpadDown))
				moveBack = true;
				dpad_move = true;
			MoveScale = 1.0f;
			if ((moveForward && moveLeft) || (moveForward && moveRight) ||
				(moveBack && moveLeft) || (moveBack && moveRight))
				MoveScale = 0.70710678f;
			// No positional movement if we are in the air
			if (!Controller.isGrounded)
				MoveScale = 0.0f;
			MoveScale *= SimulationRate * Time.deltaTime;
			// Compute this for key movement
			float moveInfluence = Acceleration * 0.1f * MoveScale * MoveScaleMultiplier;
			// Run!
			if (dpad_move || Input.GetKey(KeyCode.LeftShift) || Input.GetKey(KeyCode.RightShift))
				moveInfluence *= 2.0f;
			Quaternion ort = transform.rotation;
			Vector3 ortEuler = ort.eulerAngles;
			ortEuler.z = ortEuler.x = 0f;
			ort = Quaternion.Euler(ortEuler);
			if (moveForward)
				MoveThrottle += ort * (transform.lossyScale.z * moveInfluence * Vector3.forward);
			if (moveBack)
				MoveThrottle += ort * (transform.lossyScale.z * moveInfluence * BackAndSideDampen * Vector3.back);
			if (moveLeft)
				MoveThrottle += ort * (transform.lossyScale.x * moveInfluence * BackAndSideDampen * Vector3.left);
			if (moveRight)
				MoveThrottle += ort * (transform.lossyScale.x * moveInfluence * BackAndSideDampen * Vector3.right);
#if !UNITY_ANDROID // LeftTrigger not avail on Android game pad
			moveInfluence *= 1.0f + OVRInput.Get(OVRInput.Axis1D.PrimaryIndexTrigger);
#endif
			Vector2 primaryAxis = OVRInput.Get(OVRInput.Axis2D.PrimaryThumbstick);
			// If speed quantization is enabled, adjust the input to the number of fixed speed steps.
			if (FixedSpeedSteps > 0)
				primaryAxis.y = Mathf.Round(primaryAxis.y * FixedSpeedSteps) / FixedSpeedSteps;
				primaryAxis.x = Mathf.Round(primaryAxis.x * FixedSpeedSteps) / FixedSpeedSteps;
			if (primaryAxis.y > 0.0f)
				MoveThrottle += ort * (primaryAxis.y * transform.lossyScale.z * moveInfluence * Vector3.forward);
			if (primaryAxis.y < 0.0f)
				MoveThrottle += ort * (Mathf.Abs(primaryAxis.y) * transform.lossyScale.z * moveInfluence *
			if (primaryAxis.x < 0.0f)
				MoveThrottle += ort * (Mathf.Abs(primaryAxis.x) * transform.lossyScale.x * moveInfluence *
			if (primaryAxis.x > 0.0f)
				MoveThrottle += ort * (primaryAxis.x * transform.lossyScale.x * moveInfluence * BackAndSideDampen *
									   Vector3.right);
		if (EnableRotation)
			Vector3 euler = transform.rotation.eulerAngles;
			float rotateInfluence = SimulationRate * Time.deltaTime * RotationAmount * RotationScaleMultiplier;
			bool curHatLeft = OVRInput.Get(OVRInput.Button.PrimaryShoulder);
			if (curHatLeft && !prevHatLeft)
				euler.y -= RotationRatchet;
			prevHatLeft = curHatLeft;
			bool curHatRight = OVRInput.Get(OVRInput.Button.SecondaryShoulder);
			if (curHatRight && !prevHatRight)
				euler.y += RotationRatchet;
			prevHatRight = curHatRight;
			euler.y += buttonRotation;
#if !UNITY_ANDROID || UNITY_EDITOR
			if (!SkipMouseRotation)
				euler.y += Input.GetAxis("Mouse X") * rotateInfluence * 3.25f;
#endif
			if (SnapRotation)
				if (OVRInput.Get(OVRInput.Button.SecondaryThumbstickLeft) ||
					(RotationEitherThumbstick && OVRInput.Get(OVRInput.Button.PrimaryThumbstickLeft)))
					if (ReadyToSnapTurn)
						ReadyToSnapTurn = false;
				else if (OVRInput.Get(OVRInput.Button.SecondaryThumbstickRight) ||
					(RotationEitherThumbstick && OVRInput.Get(OVRInput.Button.PrimaryThumbstickRight)))
					ReadyToSnapTurn = true;
				Vector2 secondaryAxis = OVRInput.Get(OVRInput.Axis2D.SecondaryThumbstick);
				if (RotationEitherThumbstick)
					Vector2 altSecondaryAxis = OVRInput.Get(OVRInput.Axis2D.PrimaryThumbstick);
					if (secondaryAxis.sqrMagnitude < altSecondaryAxis.sqrMagnitude)
						secondaryAxis = altSecondaryAxis;
				euler.y += secondaryAxis.x * rotateInfluence;
			transform.rotation = Quaternion.Euler(euler);
	/// <summary>
	/// Invoked by OVRCameraRig's UpdatedAnchors callback. Allows the Hmd rotation to update the facing direction of the player.
	/// </summary>
	public void UpdateTransform(OVRCameraRig rig)
		Transform root = CameraRig.trackingSpace;
		Transform centerEye = CameraRig.centerEyeAnchor;
		if (HmdRotatesY && !Teleported)
			Vector3 prevPos = root.position;
			Quaternion prevRot = root.rotation;
			transform.rotation = Quaternion.Euler(0.0f, centerEye.rotation.eulerAngles.y, 0.0f);
			root.position = prevPos;
			root.rotation = prevRot;
		UpdateController();
		if (TransformUpdated != null)
			TransformUpdated(root);
	/// <summary>
	/// Jump! Must be enabled manually.
	/// </summary>
	public bool Jump()
			return false;
		MoveThrottle += new Vector3(0, transform.lossyScale.y * JumpForce, 0);
		return true;
	/// <summary>
	/// Stop this instance.
	/// </summary>
	public void Stop()
		Controller.Move(Vector3.zero);
		FallSpeed = 0.0f;
	/// <summary>
	/// Gets the move scale multiplier.
	/// </summary>
	/// <param name="moveScaleMultiplier">Move scale multiplier.</param>
	public void GetMoveScaleMultiplier(ref float moveScaleMultiplier)
		moveScaleMultiplier = MoveScaleMultiplier;
	/// <summary>
	/// Sets the move scale multiplier.
	/// </summary>
	public void SetMoveScaleMultiplier(float moveScaleMultiplier)
		MoveScaleMultiplier = moveScaleMultiplier;
	/// <summary>
	/// Gets the rotation scale multiplier.
	/// </summary>
	/// <param name="rotationScaleMultiplier">Rotation scale multiplier.</param>
	public void GetRotationScaleMultiplier(ref float rotationScaleMultiplier)
		rotationScaleMultiplier = RotationScaleMultiplier;
	/// <summary>
	/// Sets the rotation scale multiplier.
	/// </summary>
	public void SetRotationScaleMultiplier(float rotationScaleMultiplier)
		RotationScaleMultiplier = rotationScaleMultiplier;
	/// <summary>
	/// Gets the allow mouse rotation.
	/// </summary>
	/// <param name="skipMouseRotation">Allow mouse rotation.</param>
	public void GetSkipMouseRotation(ref bool skipMouseRotation)
		skipMouseRotation = SkipMouseRotation;
	/// <summary>
	/// Sets the allow mouse rotation.
	/// </summary>
	/// <param name="skipMouseRotation">If set to <c>true</c> allow mouse rotation.</param>
	public void SetSkipMouseRotation(bool skipMouseRotation)
		SkipMouseRotation = skipMouseRotation;
	/// <summary>
	/// Gets the halt update movement.
	/// </summary>
	/// <param name="haltUpdateMovement">Halt update movement.</param>
	public void GetHaltUpdateMovement(ref bool haltUpdateMovement)
		haltUpdateMovement = HaltUpdateMovement;
	/// <summary>
	/// Sets the halt update movement.
	/// </summary>
	/// <param name="haltUpdateMovement">If set to <c>true</c> halt update movement.</param>
	public void SetHaltUpdateMovement(bool haltUpdateMovement)
		HaltUpdateMovement = haltUpdateMovement;
	/// <summary>
	/// Resets the player look rotation when the device orientation is reset.
	/// </summary>
	public void ResetOrientation()
		if (HmdResetsY && !HmdRotatesY)
			euler.y = InitialYRotation;
Esp32 code
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
String ltr;
int intInput;
BluetoothSerial SerialBT;
   SerialBT.begin("ESP32test"); //Bluetooth device name
   Serial.println("The device started, now you can pair it with bluetooth!");
   Serial.setTimeout(50); //set timeout to 50 milliseconds instead of default 1000 milliseconds
  int lf = 10;  //ASCII character 10 is newline
  if (SerialBT.available() > 0){
   ltr = SerialBT.readString();
   Serial.println(ltr);
   intInput = ltr.toInt();
   Serial.println(intInput);
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
Isn't pasting the code to pastebin the same thing? You can read it pretty clearly and copy and paste all the code instantly. I guess I can paste the code on here too.
Not at all because it involves visiting an external site, which is completely unnecessary
Thanks for posting it here
