Sending and reading data using a network shield to a SQL server
Good day fellow Arduino Programmers
I am busy developing a productivity monitoring system and would like to ask if anyone can assist me with some example code.
I need to send and read data from a SQL server , I have only seen examples for this to a MySQL server.
Any help will be highly appreciated.
Kind Regards
NP Walbrugh
Most likely you will not want to communicate with the SQL server. You want to send data to X and receive data from X - wahtever X may be. Easiest form: X is websocket and you send UDP packages. Or X is a webserver and you send data with POST or GET. Or X is a MQTT broker. Or ... It does not matter if X talks to a database or with /dev/null.
Thanks for your response, i will look into what you said.
