I need some help to understand better how do I create a program in my PC or any other device with bluetooth adapter to comunicate with Arduino BT. It was in a wrong session, and I belive that Software >> Interfaceing is more accurance.
As I could understand, Arduino BT uses a simple serial communication with external devices via Bluetooth (computer, phone, palms, etc.). I just have to programming the serial port (bluetooth) for configuration, read the serial port, and as soon as any data is avalilable, I have just to get it and it's ok. If I need send data out, I just have to send it via serial communication.
My question is: In my computer (or mobile phone), bluetooth adapter is not a serial device. I have to create a Java or C++ program to read/write the bluetooth adapter port.
How it works? Do I have to implement all bluetooth stack (device inquiry, service inquiry, etc.)? [u]Can you share with me a small source code in Java, C++ or C for PC that send or receive data via Blueetoth adapter to/from Arduino BT?[/u] I mean, a source code that will be compiled in a computer to send and receive data from/to Arduino?
It depends on the bluetooth adapter you're using and the interface its drivers provide to other applications. You might be best off trying to find a bluetooth adapter with a virtual com port driver. I believe the built-in bluetooth on most Macs does this, for example.
I want use my mobile phone (nokia, motorola, ericsson, sony ericsson, etc.) to send some data to Arduino using bluetooth. I mean, I want create a small application and send string commands like "left", "right", "forward", "backward", receive it in Arduino BT and control a device using digital pins. Is is just like a exemple using Phyton (http://www.arduino.cc/playground/Interfacing/Python) but I need send data to Arduino from a Mobile, a computer, a Palm, etc. using a comercial programming language.
The sketch code inside Arduino looks simple. I have to configure the serial port and read the data received from this serial port. If it's a "left" command, I'll use pin (analogic or digital) to control one servo (eletronic engine - motor). If it's a "right" command, I'll use another pin... and so on...
My question is: How to create a software to use the bluetooth from my mobile or my computer to open a socket or a serial port (I don't know how this two options works over bluetooth) to send this data via bluetooth, and this data will be read by Arduino BT?
I've been reading some bluetooth manuals, and there are a lot of stacks to identify devices, identify services, send files over bluetooth. I don't need this, I just need send "HELLO" from any computer to Arduino using Bluetooth devices.
In my comments I told everybody that there is a example in Pynton that is not what I want... I need write a program that can run in different machines... Pynton is not a commercial programming language. It just works in S60 mobiles phone.
Yes, I google my questions/requests all the time. It was the first example I saw. And I also encourage people to use the Google all the time.
What I want is "a small source code in Java, C++ or C for PC that send or receive data via Blueetoth adapter to/from Arduino BT". Pynton is not a option to me.
