Sending and Receiving Messages Using SIM800
I am unable to get the following code working. Or atleast don't know how to handle the Char 's' & 'r'.
Any kind of help is welcome.
serialSIM800.listen();
  //while (!serialSIM800.available()) {}
  while (serialSIM800.available() > 0)
    Serial.println("Listening to serialSIM800");
    if (Serial.available() > 0)
      switch (Serial.read())
        case 's':
          SendMessage();
        case 'r':
          RecieveMessage();
        case '@':
          TestNode();
    if (serialSIM800.available()) {
      Serial.write(serialSIM800.read());
void SendMessage()
  //Send SMS
  //Following SMS will be Used as SMSText Value
  //Alert: Your Check Out is delayed more than 30min. Please Check Out Immediately. Warden
  //Alert: Your Check In is delayed more than 30min. Please Check In Immediately. Warden
  Serial.println("Commencig SMS Send");
  serialSIM800.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);           // Delay of 1000 milli seconds or 1 second
  Serial.println(MobileNumber);
  serialSIM800.println("AT+CMGS=\"" + MobileNumber + "\"\r\n");    //Send new SMS command and message number
  Serial.println(SMSText);
  serialSIM800.println(SMSText); //Send SMS content
  delay(100);
  serialSIM800.println((char)26); //Send Ctrl+Z / ESC to denote SMS message is complete
  Serial.println("SMS Sent");
void RecieveMessage()
  //To Recieve SMS from SIM800
  Serial.println("Readinng SMS Start");
  serialSIM800.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
  Serial.println("Reading SMS Ended");
void serialEvent() {
  MobileNumber;
  SMSText;
  strValue;
  while (Serial.available()) {
    // get the new byte:
    char ch = (char)Serial.read();
    // add it to the inputString:
    strValue += ch;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (ch == '\n') {
      if (strValue.startsWith("+91") && IsNumeric(strValue))
        MobileNumber = strValue; //Mobile Number Detected
        //strValue.toCharArray(MobileNumber, strValue.length());
      else if (IsNumeric(strValue))
        tBaud = strValue.toInt(); //Baud Speed Detected
      else if (strValue.length() > 20)
        SMSText = strValue; //SMS Text Detected
        //strValue.toCharArray(SMSText, strValue.length());
        //index = 0;
        strValue = "";
      stringComplete = true;
boolean IsNumeric(String str) {
  if (str.length()) {
    //Serial.println(str);
    for (char i = 0; i < str.length(); i++) {
      if ( !(isDigit(str.charAt(i)) || str.charAt(i) == '.' )) {
        return false;
    return true;
  else {
    return false;
void TestNode()
  //Read SIM800 output (if available) and print it in Arduino IDE Serial Monitor
  //Read Arduino IDE Serial Monitor inputs (if available) and send them to SIM800
  if (Serial.available()) {
    serialSIM800.write(Serial.read());
        case 's':
While there is data in bucket 1, read from bucket 2. What are the odds that that will work?
I am looking for help? Maybe a little tweaking for it work.
This Line onwards is Added on 20 Nov 16.
I have solved my problem. Thank you friends.
