So, I'm trying to build a little robot controller using the Ethernet shield and I'd like to take two structures and send and receive data using them.
struct received {
int pwm1;
int pwm2;
int pwm3;
int pwm4;
unsigned char DO0;
unsigned char DO1;
unsigned char DO2;
unsigned char DO3;
struct sent {
int analog0;
int analog1;
int analog2;
int analog3;
unsigned char DI0;
unsigned char DI1;
unsigned char DI2;
unsigned char DI3;
How do I convert them to and from a byte array to be send via UDP.
byte DataIn[28];
Udp.readPacket(DataIn,28, remoteIp, remotePort);
DataIn ---> received
byte DataOut[28];
DataOut <--- sent
Udp.sendPacket( DataOut, remoteIp, remotePort);
Thanks for your help in advance.
Something like this should do it:
Udp.sendPacket( (byte *) &sent, remoteIp, remotePort);
You don't need the intermediate array. However I see a couple of problems. One is that I don't count 28 bytes there. The second is that you don't want a zero-terminated string for hopefully obvious reasons.
You need the overload that takes a length, eg.
Udp.sendPacket( (byte *) &sent, sizeof sent, remoteIp, remotePort);
For reading, something like this:
Udp.readPacket((byte *) &received, sizeof received, remoteIp, remotePort);
So I gave it a go and the compiler now hates me. I don't firmly understand how to properly address pointers so that's probably my problem.
UDPSendReceiveString_rev2.cpp: In function 'void loop()':
UDPSendReceiveString_rev2:86: error: call of overloaded 'readPacket(byte*, int, byte [4], unsigned int&)' is ambiguous
C:\arduino-0022\libraries\Ethernet/Udp.h:55: note: candidates are: int UdpClass::readPacket(uint8_t*, uint16_t, uint8_t*, uint16_t*)
C:\arduino-0022\libraries\Ethernet/Udp.h:57: note: int UdpClass::readPacket(char*, uint16_t, uint8_t*, uint16_t&)
struct received {
int pwm1;
int pwm2;
int pwm3;
int pwm4;
unsigned char DIO0;
unsigned char DIO1;
unsigned char DIO2;
unsigned char DIO3;
struct sent {
int analog0;
int analog1;
int analog2;
int analog3;
unsigned char DI0;
unsigned char DI1;
unsigned char DI2;
unsigned char DI3;
struct received *dataIn;
struct send *dataOut;
// if there's data available, read a packet
int packetSize = Udp.available(); // note that this includes the UDP header
if(packetSize)
packetSize = packetSize - 8; // subtract the 8 byte header
Udp.sendPacket( (byte *) &dataOut, 12, remoteIp, remotePort);
Udp.readPacket( (byte *) &dataIn, 12, remoteIp, remotePort);
kingofl337:
It doesn't hate you. It doesn't have feelings.
Your problem in this case was the 4th argument (remotePort) which as you can see from the error message is expected to be a pointer. The amended version below compiles. I can't say whether it works, but it compiles without errors.
#include <SPI.h> // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <Udp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte remoteIp[] = {
192,168,1,177 };
unsigned int localPort = 8888; // local port to listen on
unsigned int remotePort;
struct received {
int pwm1;
int pwm2;
int pwm3;
int pwm4;
unsigned char DIO0;
unsigned char DIO1;
unsigned char DIO2;
unsigned char DIO3;
struct sent {
int analog0;
int analog1;
int analog2;
int analog3;
unsigned char DI0;
unsigned char DI1;
unsigned char DI2;
unsigned char DI3;
void setup ()
// start the Ethernet and UDP:
Ethernet.begin(mac,remoteIp);
Udp.begin(localPort);
if(packetSize)
Udp.readPacket( (byte *) &dataIn, 12, remoteIp, &remotePort);
I'm not sure about this stuff:
if(packetSize)
What if packetSize happens to be 2? You subtract 8, giving -6.
