Hi everyone... I’m newbie in Arduino IDE programming. I worked on my graduation project here. My project is to send data from ethernet arduino using sensor INA219 from arduino to database MySQL. I got error ‘sendDB’ was not declared in this scope error during the compilation process. What to do so that "sendToDB" doesn't make errors? This is my code. If there are any mistakes in my code, can anyone help correct them? I appreciate any help. TIA~~
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 sensor219 (0x41);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //MAC Address
float DataVoltage;
float DataCurrent;
int period = 30000; //interval save data to db
unsigned long time_now = 0;
unsigned long byteCount = 0;
bool printWebData = true; // set to false for better speed measurement
char server[] = "192.168.10.10";
IPAddress ip(192,168,10,5); //arduino IP
EthernetClient client;
sensor219.begin();
Ethernet.begin(mac, ip);
Serial.print("Local IP: ");
Serial.println(Ethernet.localIP());
delay(2000);
if(millis() >= time_now + period){
time_now += period;
SendtoDB();
int len = client.available();
if (len > 0) {
byte buffer[80];
if (len > 80) len = 80;
client.read(buffer, len);
if (printWebData) {
Serial.write(buffer, len); // show in the serial monitor (slows some boards)
byteCount = byteCount + len;
//insert data ke DB via injeksi control.php
void SendtoDB(){
if (client.connect(server, 80))
Serial.println("");
Serial.println("connected");
// Make a HTTP request:
Serial.print("GET /arduino_mysql/control.php?dataVoltage=");
Serial.print(DataVoltage);
Serial.print("&dataCurrent=");
Serial.println(DataCurrent);
Serial.println("");
client.print("GET /arduino_mysql/control.php?dataVoltage="); //YOUR URL
client.print(DataVoltage);
client.print("&dataCurrent=");
client.print(DataCurrent);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.println();
client.println("Host: 192.168.10.5");
client.println("Connection: close");
client.println();
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
and here my script to insert data to Database
<?php
class ethernet{
public $link='';
function __construct($current, $voltage){
$this->connect();
$this->storeInDB($current, $voltage);
function connect(){
$this->link = mysqli_connect('localhost','root','') or die('Cannot connect to the DB');
mysqli_select_db($this->link,'arduino_sensor') or die('Cannot select the DB');
function storeInDB($current, $voltage){
$query = "insert into sensor_ethernet set voltage='".$voltage."', current='".$current."'";
$result = mysqli_query($this->link,$query) or die('Errant query: '.$query);
if($result === TRUE){echo "Data Tersimpan";}else{echo "Gagal Menyimpan data";}
if($_GET['dataCurrent'] != '' and $_GET['dataVoltage'] != ''){
$ethernet=new ethernet($_GET['dataCurrent'],$_GET['dataVoltage']);
