Sending Array from Arduino to MATLAB
Hi everyone,
I've come across a problem sending serial data from my Arduino to MATLAB. I should note, I am technically doing this on a Teensy 3.1, but the problem is reproducible on an Uno.
As part of a testing program I have written, I send a 900-element array of uint8 data from MATLAB to the Arduino and then back again. Sending the data from MATLAB to the Arduino works great, no problems. I can echo this array to the serial monitor and everything is peachy.
However, I want to be able to send this array directly back into MATLAB (eventually in near real-time). After doing some reading, it appears that one can either use the fread function directly or fscanf inside a loop to read a fixed amount of binary data into MATLAB from the (connected) serial port. However, no matter what I try, I always receive a "Warning: The specified amount of data was not returned within the Timeout period." Here is some minimal example code that reproduces the problem:
Arduino
const int button1=8;
byte data_array[900];
void setup(){
pinMode(button1,INPUT);
digitalWrite(button1,HIGH);
void loop(){
if(Serial.available()){Serial.readBytes((char*)data_array,900);}
if(digitalRead(button1)==LOW){
    delay(5);
   while(digitalRead(button1) ==LOW){delay(5);}
for(int i=0;i<900;i++){Serial.print(data_array[i]);}
MATLAB
COM1=serial('/dev/tty.usbmodem26511','BaudRate',115200,'OutputBufferSize',900,'InputBufferSize',900);
fopen(COM1);
pause(1);
data_in=uint8(randi(240,[900,1]));
fwrite(COM1,data_in,'uint8');
data_out=fread(COM1,900,'uint8');
fclose(COM1);
As I said, the Arduino can print data_array just fine to a standard Serial terminal.
Things I have tried:
  1. Setting the MATLAB input buffer and read length to very low values, e.g. 100, in case a few bytes were missing from the received array.
  2. Replacing fread with fscanf (formatted for decimals) in a loop.
  3. Setting different timeout periods for the MATLAB serial reads.
I've seen a few people with similar issues on different forums, but I can't find anybody who seems to have resolved the problem. I would be appreciative of any help.
Thanks,
MrFisher
I have the same question like u. Have u solved it?
