Sending AT commands to USR ethernet module.
Hi guys:
I have my arduino uno connected to usr-tcp232-t2 via serial interface.
Project works ok , I can send and receive data over the network.
Now , I would like to read ethernet module mac address during setup loop.
Documentation says it is possible to read mac address using AT commands.
After contanting vendor support , explained how to do it but did not provide any working example.
I need to send the "+++a" string , then the "AT+MAC" command , followed by "\r\n"
This is what im doing:
String str1 = "";
String str2 = "";
void setup(){
   str1.reserve(200);
   str2.reserve(200);
    delay(2000);
    Serial.println("+++");
    while(Serial.available() > 0 ){
     str1 = Serial.readString();
    Serial.println("a");
    Serial.println("AT+MAC\r\n");
     str2 = Serial.readString();
Serial.print("data from AT:");
Serial.println(str2);
Well ... this is not working.
btw:
Baud rate is ok , I strings are going properly out of the network but can not read mac address.
Any advice would be wellcome.
Leandro.
Perhaps this line:
should be
Serial.print("+++");
If you wan to send "+++a" you don't want a newline after the "+++"
