Sending AT commands with no line ending for HM-10
I need to use HM-10 with Arduino Uno or Nano.
I'm not able to figure out how to send AT commands and read the reply.
Here's what I've tried so far:
#include <SoftwareSerial.h>
SoftwareSerial blueToothSerial(0,1); // RX, TX
  Serial.println("Serial began");
  blueToothSerial.begin(9600);
  delay(2000);
  Serial.println("looping...");
  blueToothSerial.print("AT+DISC?");
  delay(5000);
  if (blueToothSerial.available())
    Serial.println("bluetooth serial available");
    Serial.write(blueToothSerial.read());
  if (Serial.available())
    blueToothSerial.write(Serial.read());
However, I'm not able to read any reply, I feel the command is not firing. The execution doesnt go inside if(blueToothSerial.available())
dushyantbangal:
Fatal mistake. You are using hardware serial pins 0,1 for software serial. Put it somewhere else, like pins 2,3.
Nick_Pyner:
No, I've tried it on 3,4 and many others.
Read reply #1 again.
dushyantbangal:
I know this is a bit old, but I had the same issue and I kept finding this thread when searching.
For me, using blueToothSerial.write (instead of blueToothSerial.print) worked (and yes, required pins other than 0/1). My module doesn't require the new line or carriage return characters, you'll need to add those if yours does.
