I am trying to send packets of 7 bytes of data, all will be numbers between 0 and 255. The data is sent with xBee.print(255), but when it is received, it comes over as the ascii representation of each digit....50,53,53.
I am including the source, but my guess is that I just don't understand sending data through serial ports. Any advice would be greatly appriciated.
Heres the sending code....
#include <SoftwareSerial.h>
SoftwareSerial xBee = SoftwareSerial(2,3);
int hPin = 1; // Joystick Horizontal Pot data
int vPin = 0; // Joystick Vertical Pot data
int valV = 0; // Vertical data
int valH = 0; // Horizontal data
int V = 0; // remapped vertical data
int H = 0; // remapped horizontal data
//int pkt[10];
xBee.begin(9600);
Serial.println("Sending...");
// read the joy stick poteniometors
valV=analogRead(vPin);
valH=analogRead(hPin);
//convert analog signal to the range 0 to 250
V=map(valV,0,1024,0,250);
H=map(valH,0,1024,0,250);
sendStatus(valV,valH,1,2,3,4); // Send out through xBee
delay(100);
void sendStatus(byte V, byte H, byte s1, byte s2, byte s3, byte s4) {
int HB=5; // this is the heart beat. If the Rx does not recieve
// this every cycle, it will automatically stop the motors
Serial.print(255);
Serial.print(",");
Serial.print(V);
Serial.print(",");
Serial.print(H);
Serial.print(",");
Serial.print(s1);
Serial.print(",");
Serial.print(s2);
Serial.print(",");
Serial.print(s3);
Serial.print(",");
Serial.print(s4);
Serial.print(",");
Serial.print(HB);
Serial.print(",");
Serial.println(254);
xBee.print(255);
xBee.print(V);
xBee.print(H);
xBee.print(s1);
xBee.print(s2);
xBee.print(s3);
xBee.print(s4);
xBee.print(HB);
xBee.println(254);
and heres the receiving code....
SoftwareSerial xBee(2, 3); // RX, TX
int V;
int H;
int HB=5;
Serial.println("Running...");
xBee.begin(9600);
void loop() // run over and over
if (xBee.available()) {
byte ch = xBee.read();
delay(15);
Serial.println(ch); // for debugging
if (ch == 255) { // this is were I am seeing the problem. I send 255 and get the ascii codes 50,53,53.
getData(); // now do I get this as a signel byte????????????????
void getData() {
byte c = 0;
int n = 0;
byte dta[6];
while (c != 254) {
c = xBee.read();
if (c != 254) {
dta[n]=c+1000;
n++;
// this is ment to convert from a linear progression to exponential progress at the end points.
// and shift from 0 to 250 back to -125 to 125
// not being used until I can figure out what I am doing wrong on getting the data from xBee
byte V = dta[0]; //(pow(dta[0],3)/15876)-126;
byte H = dta[1]; //(pow(dta[1],3)/15876)-126;
byte HB = dta[6];
// Just for debugging. Will eventually be sent to the motor controller.
Serial.print("V = ");
Serial.print(V);
Serial.print(", H = ");
Serial.print(H);
Serial.print(", s1 = ");
Serial.print(dta[2]);
Serial.print(", s2 = ");
Serial.print(dta[3]);
Serial.print(", s3 = ");
Serial.print(dta[4]);
Serial.print(", s4 = ");
Serial.print(dta[5]);
Serial.print(", HB = ");
Serial.println(HB);
