Sending char Array via Bluetooth in ESP32
Hi everyone,
I used this simple sketch to sending char array from ESP32 to my laptop via Bluetooth communication.
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
#if !defined(CONFIG_BT_SPP_ENABLED)
#error Serial Bluetooth not available or not enabled. It is only available for the ESP32 chip.
#endif
char aaa[128] = {"Hello_Everyone...This_is_char_arry_from_ESP32_device..."};
BluetoothSerial SerialBT;
  SerialBT.begin("ESP32test");
  Serial.println("The device started, now you can pair it with bluetooth!");
    SerialBT.write(*aaa);
  delay(20);
I used Bluetooth Serial Terminal software for receive data in my laptop. but it shows output as
HHHHHHHHHHHHHHHHHHHHH
I need your help to solve this problem. My array is much large and how to send it via Bluetooth to get known sentence.
Thank You.
*aaa is just the first byte of your message, a char. so it sends the 'H' every 20ms which is why you see HHHHHHHHHHHHHHHHHHHHH
try
#endif
#endif
char message[] = "Hello_Everyone.";
    SerialBT.write(message, strlen(message));
  delay(5000);
there is indeed a max size for the payload. You'll have to deal with that.
