Hello, I'm currenctly programming a robot for a school project. I have 3 ultrasonic sensors (HC-SR04) . I'm using 2 arduinos, 1 as a slave, which just drives the motors and the other as a master. On the master one, I'm sending characters 'A' (Go forward) 'G' (Go left) 'D' (Go right) 'M' (End of the run). I'm using the uart on D0-D1 as a serial communication. I don't get why but when I send data I get AGDM on the serial of the first card, then only A0 on the second card. Why is that ?
Here is both important codes (Slave first) :
char etat;
if(Serial.available())
etat = Serial.read();
Serial.println(etat);
//Serial.println(angle_rotation);
switch (etat) {
case 'A':
//VERIFICATION DE LA ROTATION
if (angle_rotation != 0) {
//SI PAS ENCORE AVANCE POUR QUITTER L'ANGLE
if (AVANCER) {
avance(1000, VMAX);
AVANCER = false;
//TOURNE A DROITE
if (angle_rotation < 0) {
tourne_droite();
//TOURNE A GAUCHE
if (angle_rotation > 0) {
tourne_gauche();
else {
//avance(250, VMAX);
AVANCER = true;
case 'G':
//TOURNE A GAUCHE
pause();
tourne_gauche();
case 'D':
//TOURNE A DROITE
pause();
tourne_droite();
case 'M':
Master one :
Serial.begin(9600); // Starts the serial communication
pinMode(ST,INPUT);
pinMode(SC,INPUT);
pinMode(POWER,INPUT);
// pinMode(ENA, OUTPUT); // sets the pin as output
// pinMode(ENB, OUTPUT); // sets the pin as output
// pinMode(G1, OUTPUT); // sets the pin as output
delay(50);
distance_gauche = capteur_gauche.ping() / US_ROUNDTRIP_CM;
distance_droite = capteur_droite.ping() / US_ROUNDTRIP_CM;
distance_centre = capteur_centre.ping() / US_ROUNDTRIP_CM;
/* Envoi en uart de données sur le second arduino:
* G = Gauche, D = Droite, C = Centre (mur), A = Avance */
// DISTANCE GAUCHE ONLY
if((distance_gauche > 0 && distance_gauche < DISTANCE_RIEN)&&(distance_droite == 0 || distance_droite > DISTANCE_RIEN)){
Serial.write('G');
delay (100);
// DISTANCE DROITE ONLY
if((distance_droite > 0 && distance_droite < DISTANCE_RIEN)&&(distance_gauche == 0 || distance_gauche > DISTANCE_RIEN)){
Serial.write('D');
delay (100);
// DISTANCE MUR
if((distance_droite > 0 && distance_droite <= DISTANCE_RIEN)&&(distance_gauche > 0 && distance_gauche <= DISTANCE_RIEN)){
Serial.write('M');
delay (100);
// DETECTE RIEN
if((distance_droite == 0 || distance_droite > DISTANCE_RIEN)&&(distance_gauche == 0 || distance_gauche > DISTANCE_RIEN)){
Serial.write('A');
delay (100);
There's the whole code if I've missed something.
Here's my code for the master :
#include <NewPing.h>
/* EC-X = Echo capteur X TC-X = Trigger capteur X
* G = gauche C = centre D = droite */
#define ECG 2
#define ECC 3
#define ECD 4
#define TCG 6
#define TCC 7
#define TCD 8
#define DISTANCE_RIEN 25
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define ST 10 //Servo tourelle
#define SC 11 //Servo capteur
#define POWER 12 //Switch on/off du programme
#define G2 7 // commande transistor 2 sur broche 7
unsigned int distance_gauche, distance_droite, distance_centre;
NewPing capteur_gauche(TCG, ECG, 50);
NewPing capteur_droite(TCD, ECD, 50);
NewPing capteur_centre(TCC, ECC, 50);
pinMode(ST,INPUT);
pinMode(SC,INPUT);
delay(50);
Serial.write('G');
delay (100);
Serial.write('D');
delay (100);
// DISTANCE MUR
Serial.write('M');
delay (100);
// DETECTE RIEN
Serial.write('A');
delay (100);
and my code for the slave (I think it's the slave)
#define ENA 3 // validation pont A sur broche 3
#define ENB 5 // validation pont B sur broche 5
/* Le moteur de droite est le A, gauche le B
si (IN1,H / IN2,L) si (IN3,H / IN4,l) alors
le robot va tout droit */
#define IN1 9 // commande demi-pont 1 (A) sur broche 9
#define IN2 10 // commande demi-pont 2 (A) sur broche 10
#define IN3 12 // commande demi-pont 3 (B) sur broche 12
#define IN4 13 // commande demi-pont 4 (B) sur broche 13
#define G1 6 // commande transistor 1 sur broche 6
#define VMAX 240
#define V50 120
#define VMIN 60
bool AVANCER = true;
int angle_rotation;
char etat;
pinMode(G2, OUTPUT); // sets the pin as output
pinMode(IN1, OUTPUT); // sets the pin as output
pinMode(IN2, OUTPUT); // sets the pin as output
pinMode(IN3, OUTPUT); // sets the pin as output
pinMode(IN4, OUTPUT); // sets the pin as output
digitalWrite(G2, LOW); // relais 2 OFF
digitalWrite(G1, LOW); // relais 1 OFF
analogWrite(ENA, 0); // arrĂȘt du moteur A
analogWrite(ENB, 0); // arrĂȘt du moteur B
/* Lecture de l'état affilié à la course en fonction des capteurs
A = avance tout droit (si pas de capteurs detectent)
G = tourne Ă gauche (seulement si capteur droite detecte)
D = tourne Ă droite (seulement si capteur gauche detecte)
M = mur final (si les deux capteurs detectent)
if(etat == 'A'){
Serial.println("Avancer");
if(etat == 'D'){
Serial.println("Droite");
if(etat == 'G'){
Serial.println("Gauche");
if(etat == 'M'){
Serial.println("Milieu");
switch (etat) {
case 'A':
if (AVANCER) {
avance(1000, VMAX);
AVANCER = false;
//TOURNE A DROITE
tourne_droite();
//TOURNE A GAUCHE
tourne_gauche();
else {
AVANCER = true;
case 'G':
//TOURNE A GAUCHE
pause();
tourne_gauche();
case 'D':
//TOURNE A DROITE
pause();
tourne_droite();
case 'M':
int pause() {
digitalWrite(IN1, LOW); // moteur A tourne dans sens -
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW); // moteur A tourne dans sens -
digitalWrite(IN4, LOW);
delay(300);
int tourne_gauche() {
digitalWrite(IN1, HIGH); // moteur A tourne dans sens -
analogWrite(ENA, V50); // moteur A vitesse 1/2
digitalWrite(IN3, HIGH); // moteur A tourne dans sens -
analogWrite(ENB, V50); // moteur A vitesse 1/2
angle_rotation -= 1;
delay(250);
int tourne_droite() {
digitalWrite(IN2, HIGH);
digitalWrite(IN4, HIGH);
angle_rotation += 1;
delay(250);
int avance(int delai, int vitesse) {
analogWrite(ENA, vitesse); // moteur A vitesse 1/2
analogWrite(ENB, vitesse); // moteur A vitesse 1/2
delay(delai);
