Sending client a web page stored in spiffs
I have a first homepage index.html which serves me to verify the login and the password that I transmit by post and check. So far so good, but if the passwords and login are good I cannot send back to the client the new web page stored in spiffs, for example, "accept.html" stored in Spiffs,
Thank you for your response.
void handleLogin() {
Serial.println (" Ok");
Serial.print ("Server argument username :");
Serial.println (server.arg("username"));
Serial.print ("Server argument password :");
Serial.println (server.arg("password"));
  if( ! server.hasArg("username") || ! server.hasArg("password")
      || server.arg("username") == NULL || server.arg("password") == NULL)
    server.send(400, "text/plain", "400: Invalid Request");
    return;
  if(server.arg("username") == "XXXX" && server.arg("password") == "YYYY") {
    Serial.println("Useername and password OK");
 // here is my question
// I want to send "accepte.html" stored in SPIFFS to the client but i don't find the correct syntax
  else {
    server.send(401, "text/plain", "401: Unauthorized");
SPIFFS is SPI Flash File System, just like any old file system on a computer. You will need to open and read the html file into a string, in your case accepte.html. Then print it out to your client using Server.send();
I'm using a handler like this
void handleInternalCss() {
  String pathWithExtension = "/i.css";
  if (SPIFFS.exists(pathWithExtension)) {
    Serial.println(F("D43 stylsheet found on SPIFFS"));
    File file = SPIFFS.open(pathWithExtension, "r");
    size_t sent = server.streamFile(file, "text/css");
    file.close();
    Serial.println(F("D49 stylsheet not found on SPIFFS"));
    handleNotFound;
take care of the MIME type if you want to send html instead of a css.
don't read it to a String buffer ... just stream it to the server
Thanks a lot,
I used the solution of noiasca and it works perfectly.
I also tried with
    String myFile = "/accepte.html";
  if (SPIFFS.exists(myFile)) {
    Serial.println(F("myFile founded on   SPIFFS"));   //ok
   File file = SPIFFS.open(myFile, "r");                    //ok
 server.send(200, "text/html", file);                     // pb but i don't really understand why, I think i send a file and not a text
Thanks again
