Sending Data between two Nano 33 BLE Senses to make a magic wand
I am trying to make a magic wand using two Nano 33 BLE Senses. My goal is to have one Arduino (the wand) collect accelerometer and voice data. When it detects a specific phrase and a motion (the motion is non specific at the moment) it then triggers an action command for the other arduino to do something. In my case the other arduino will power a small motor which will unlock a box. I am able to get the voice and motion to work together by turning on the built in blue light when both are detected within a certain time window, but I cannot seem to figure out how to get the wand arduino to send a command to the action arduino. Anyone know what I am doing wrong? Or have you made something similar that works and want to share the code? I have been trying on and off for a few months now and am getting frustrated that I can't get it to work.
This is the wand code I Frankensteined together that is not sending data.
#define GREEN 23
#define BLUE 24
#define EIDSP_QUANTIZE_FILTERBANK   0
#define EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW 3
/* Includes ---------------------------------------------------------------- */
#include <PDM.h>
#include <Alohomora_inferencing.h>
#include <Arduino_LSM9DS1.h>
#include <ArduinoBLE.h>
#include <Arduino_APDS9960.h>
//BLEService batteryService("1101");
const char* deviceServiceUuid = "19b10000-e8f2-537e-4f6c-d104768a1214";
const char* deviceServiceCharacteristicUuid = "19b10001-e8f2-537e-4f6c-d104768a1214";
BLEService gestureService(deviceServiceUuid);
BLECharacteristic gestureCharacteristic(deviceServiceCharacteristicUuid, BLERead | BLEWrite);
int gesture = -1;
int oldGestureValue = -1;
int LEDon = 0;
/** Audio buffers, pointers and selectors */
typedef struct {
    signed short *buffers[2];
    unsigned char buf_select;
    unsigned char buf_ready;
    unsigned int buf_count;
    unsigned int n_samples;
} inference_t;
static inference_t inference;
static bool record_ready = false;
static signed short *sampleBuffer;
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static int print_results = -(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW);
static const int led_pin = LED_BUILTIN;
int VoiceOn = 0;
int GsOn = 0;
 * @brief      Arduino setup function
  while (!Serial);
  if (!APDS.begin()) {
    Serial.println("* Error initializing APDS9960 sensor!");
  APDS.setGestureSensitivity(80);
  if (!BLE.begin()) {
    Serial.println("* Starting BLE module failed!");
    while (1);
  BLE.setLocalName("Nano 33 BLE (Central)");
  BLE.advertise();
  Serial.println("Arduino Nano 33 BLE Sense (Central Device)");
  Serial.println(" ");
  pinMode(led_pin, OUTPUT);
    Serial.println("Edge Impulse Inferencing Demo");
    // summary of inferencing settings (from model_metadata.h)
    ei_printf("Inferencing settings:\n");
    ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) /
                                            sizeof(ei_classifier_inferencing_categories[0]));
    run_classifier_init();
    if (microphone_inference_start(EI_CLASSIFIER_SLICE_SIZE) == false) {
        ei_printf("ERR: Failed to setup audio sampling\r\n");
        return;
  while (!Serial);
  Serial.println("Started");
  if (!IMU.begin()) {
    Serial.println("Failed to initialize IMU!");
    while (1);
  Serial.print("Accelerometer sample rate = ");
  Serial.print(IMU.accelerationSampleRate());
  Serial.println(" Hz");
  Serial.println("Acceleration in G's");
  Serial.println("X\tY\tZ");
   BLE.setAdvertisedService(gestureService);
  gestureService.addCharacteristic(gestureCharacteristic);
 * @brief      Arduino main function. Runs the inferencing loop.
   connectToPeripheral();
  startA();
 * @brief      Printf function uses vsnprintf and output using Arduino Serial
 * @param[in]  format     Variable argument list
void ei_printf(const char *format, ...) {
    static char print_buf[1024] = { 0 };
    va_list args;
    va_start(args, format);
    int r = vsnprintf(print_buf, sizeof(print_buf), format, args);
    va_end(args);
    if (r > 0) {
        Serial.write(print_buf);
void connectToPeripheral(){
  BLEDevice peripheral;
  Serial.println("- Discovering peripheral device...");
  do
    BLE.scanForUuid(deviceServiceUuid);
    peripheral = BLE.available();
  } while (!peripheral);
  if (peripheral) {
    Serial.println("* Peripheral device found!");
    Serial.print("* Device MAC address: ");
    Serial.println(peripheral.address());
    Serial.print("* Device name: ");
    Serial.println(peripheral.localName());
    Serial.print("* Advertised service UUID: ");
    Serial.println(peripheral.advertisedServiceUuid());
    BLE.stopScan();
    controlPeripheral(peripheral);
void controlPeripheral(BLEDevice peripheral) {
  Serial.println("- Connecting to peripheral device...");
  if (peripheral.connect()) {
    Serial.println("* Connected to peripheral device!");
    Serial.println("* Connection to peripheral device failed!");
    return;
  Serial.println("- Discovering peripheral device attributes...");
  if (peripheral.discoverAttributes()) {
    Serial.println("* Peripheral device attributes discovered!");
    Serial.println("* Peripheral device attributes discovery failed!");
    peripheral.disconnect();
    return;
 BLECharacteristic gestureCharacteristic = peripheral.characteristic(deviceServiceCharacteristicUuid);
  while (peripheral.connected()) {
    LEDon = startA();
   gestureCharacteristic.writeValue((byte)LEDon);
  Serial.println("- Peripheral device disconnected!");
 * @brief      PDM buffer full callback
 *             Get data and call audio thread callback
static void pdm_data_ready_inference_callback(void)
    int bytesAvailable = PDM.available();
    // read into the sample buffer
    int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable);
    if (record_ready == true) {
        for (int i = 0; i<bytesRead>> 1; i++) {
            inference.buffers[inference.buf_select][inference.buf_count++] = sampleBuffer[i];
            if (inference.buf_count >= inference.n_samples) {
                inference.buf_select ^= 1;
                inference.buf_count = 0;
                inference.buf_ready = 1;
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
static bool microphone_inference_start(uint32_t n_samples)
    inference.buffers[0] = (signed short *)malloc(n_samples * sizeof(signed short));
    if (inference.buffers[0] == NULL) {
        return false;
    inference.buffers[1] = (signed short *)malloc(n_samples * sizeof(signed short));
        free(inference.buffers[0]);
        return false;
    sampleBuffer = (signed short *)malloc((n_samples >> 1) * sizeof(signed short));
    if (sampleBuffer == NULL) {
        free(inference.buffers[1]);
        return false;
    inference.buf_select = 0;
    inference.n_samples = n_samples;
    inference.buf_ready = 0;
    // configure the data receive callback
    PDM.onReceive(&pdm_data_ready_inference_callback);
    PDM.setBufferSize((n_samples >> 1) * sizeof(int16_t));
    // initialize PDM with:
    // - one channel (mono mode)
    // - a 16 kHz sample rate
    if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start PDM!");
    // set the gain, defaults to 20
    PDM.setGain(127);
    record_ready = true;
    return true;
 * @brief      Wait on new data
 * @return     True when finished
static bool microphone_inference_record(void)
    bool ret = true;
    if (inference.buf_ready == 1) {
        ei_printf(
            "Error sample buffer overrun. Decrease the number of slices per model window "
            "(EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)\n");
        ret = false;
    while (inference.buf_ready == 0) {
        delay(1);
    return ret;
 * Get raw audio signal data
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr)
    numpy::int16_to_float(&inference.buffers[inference.buf_select ^ 1][offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    PDM.end();
    free(sampleBuffer);
int startA(){
  for (int i = 0; i <= 50; i++) {
  float x, y, z;
  if (IMU.accelerationAvailable()) {
    IMU.readAcceleration(x, y, z);
    Serial.print(x);
    Serial.print('\t');
    Serial.print(y);
    Serial.print('\t');
    Serial.println(z);
  if (abs(x) > 1.8 or abs(y) > 1.8) {
      digitalWrite(GREEN,LOW);
      GsOn = 1;
    bool m = microphone_inference_record();
    if (!m) {
        ei_printf("ERR: Failed to record audio...\n");
        return LEDon;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_SLICE_SIZE;
    signal.get_data = &microphone_audio_signal_get_data;
    ei_impulse_result_t result = {0};
    EI_IMPULSE_ERROR r = run_classifier_continuous(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", r);
        return LEDon;
    //Turn on LED if "Alohomora" value is above a threshold
    if (result.classification[0].value > 0.9)  {
      digitalWrite(led_pin, HIGH);
      VoiceOn = 1;
      digitalWrite(led_pin, LOW);
    if (++print_results >= (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)) {
        // print the predictions
        ei_printf("Predictions ");
        ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
            result.timing.dsp, result.timing.classification, result.timing.anomaly);
        ei_printf(": \n");
        for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
            ei_printf("    %s: %.5f\n", result.classification[ix].label,
                      result.classification[ix].value);
#if EI_CLASSIFIER_HAS_ANOMALY == 1
        ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
        print_results = 0;
if (VoiceOn == 1 && GsOn == 1){  //(result.classification[0].value > 0.7 && (abs(x) > 2 or abs(y) > 2) )
  //Send bluetooth commannd to motor
digitalWrite(BLUE,LOW);
  LEDon = 0;
   guestureCharacteristic.writeValue(LEDon);
  sendmessage();
    digitalWrite(GREEN, HIGH);
VoiceOn = 0;
GsOn = 0;
digitalWrite(BLUE, HIGH);
LEDon = 0;
 //sendmessage();
int sendmessage(){
//LEDon = 1;
  return LEDon;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
And this is the action Arduino code. So this code is supposed to receive the "ok" from the wand Arduino telling it to open the box.
enum {
  ON = 1,
  OFF = 0,
int LEDon = 0;
BLEByteCharacteristic gestureCharacteristic(deviceServiceCharacteristicUuid, BLERead | BLEWrite);
  while (!Serial);
  pinMode(LEDR, OUTPUT);
  pinMode(LEDG, OUTPUT);
  pinMode(LEDB, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LEDR, HIGH);
  digitalWrite(LEDG, HIGH);
  digitalWrite(LEDB, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
  if (!BLE.begin()) {
    Serial.println("- Starting BLE module failed!");
    while (1);
  BLE.setLocalName("Arduino Nano 33 BLE (Peripheral)");
  BLE.addService(gestureService);
  gestureCharacteristic.writeValue(-1);
  BLE.advertise();
  Serial.println("Nano 33 BLE (Peripheral Device)");
  BLEDevice central = BLE.central();
  Serial.println("- Discovering central device...");
  if (central) {
    Serial.println("* Connected to central device!");
    Serial.println(central.address());
    while (central.connected()) {
      if (gestureCharacteristic.written()) {
         LEDon = gestureCharacteristic.value();
         writeGesture(LEDon);
    Serial.println("* Disconnected to central device!");
void writeGesture(int LEDon) {
  Serial.println("- Characteristic <gesture_type> has changed!");
   if(LEDon = 0){
  Serial.println("* Actual value: UP (red LED on)");
        digitalWrite(LEDR, LOW);
        else if(LEDon = 1){
Serial.println("* Actual value: DOWN (green LED on)");
        digitalWrite(LEDG, LOW);
