Sending data by serial monitor for angle control of a stepper motor with gearbox
Hello everyone,
I am making a program in python using inverse kinematics to send values to my arduino mega, but I have a problem. When I send my string of characters in my arduino serial monitor, my motor does not move, in the program is detailed lines of code for now I'm just testing a motor for later use with python.
when I send my string on my monitor it would be, for example A+30B+30C+30D+30E+30F+30.
A is my first motor with positive angle of 30 degrees, the motor does not move, the other values are given to fill my string, then it will be programmed, for now I am testing with only one motor.
//nema 14 motor = 400 pasos * 13.73 = 5492/360 = 15.255556
// ratio = 13.73:1
// driver dm542t
  int PUL1 = 10;
  int DIR1 = 11;
  int SET1 = 14;
  int number_of_steps=0;                                  // We declare the variable number of steps and start it at 0
  int num1,num2,num3,num4,num5,num6;
  int teta1,teta2,teta3,teta4,teta5,teta6;
/////////// note: I am working with a motor for now for testing, its specifications are above.
  float  j1stepPerGrade = 15.255556;                                  //engine compensation value
  float  j2stepPerGrade = 15.255556;
  float  j3stepPerGrade = 15.255556;
  float  j4stepPerGrade = 15.255556;
  float  j5stepPerGrade = 15.255556;
  float  j6stepPerGrade = 15.255556;
  pinMode(PUL1,OUTPUT);
  pinMode(DIR1,OUTPUT);
  pinMode(SET1,OUTPUT);
  //pinMode(SET1, HIGH);
String data;
   ////////// //scheduled routines///////////////
    while(Serial.available())
      char character = Serial.read();           //read the character variable in the serial port
      if(character != '\n')          //verify if there is a character in the serial port if there is not it will do a line break
        data.concat(character);          //we concatenate the variable character
        Serial.println(data);                      //we print the variable te type string in the serial port
        char a[30];                                    //We declare a variable a with a vector of dimension 30
        data.toCharArray(a,30);               // matrix
        data = "";                                    //we initialize the variable string
        /////////////////////// Here starts the decoding algorithm///////////////////////////////
        //we order the values ​​of the variable "a" for a dimension of 30
        if((a[0]=='A')&&(a[4]=='B')&&(a[8]=='C')&&(a[12]=='D')&&(a[16]=='E')&&(a[20]=='F'))
          Serial.println("OK");
          char ang1[5] = {a[1],a[2],a[3]};      //We declare character type ang1 and the positions for each character
          int  num1 = atoi(ang1);                      //convert each character of ang1 to integer
          num1 = (num1*j1stepPerGrade);       //we perform a value adjustment for the stepper motors
          char ang2[5] = {a[5],a[6],a[7]};
          int  num2 = atoi(ang2);
          num2 = (num2*j2stepPerGrade);
          char ang3[5] = {a[9],a[10],a[11]};
          int  num3 = atoi(ang3);
          num3 = (num3*j3stepPerGrade);
          char ang4[5] = {a[13],a[14],a[15]};
          int  num4 = atoi(ang4);
          num4 = (num4*j4stepPerGrade);
          char ang5[5] = {a[17],a[18],a[19]};
          int  num5 = atoi(ang5);
          num5 = (num5*j5stepPerGrade);
          char ang6[5] = {a[21],a[22],a[23]};
          int  num6 = atoi(ang6);
          num6 = (num6*j6stepPerGrade);
          /////////end coding and start assigning values ​​to engines////////////////////
         teta1 = num1;
         teta2 = num2;
         teta3 = num3;
         teta4 = num4;
         teta5 = num5;
         teta6 = num6;
     while(teta1>number_of_steps)                          // Turn to the left in degrees
          s_l();
          number_of_steps=number_of_steps+1;
     while(teta1<number_of_steps)                     // Right turn in degrees
           s_r();
           number_of_steps=number_of_steps-1;
       data = "";                  // We initialize the string of received characters
       delay(2000);
       return_1();                    //we return to an initial point in this case it is 0
       shutdown_1();                 // Engine shutdown so it doesn't overheat
void s_r()                                  //steps to the right
   digitalWrite(DIR1,HIGH);
   digitalWrite(PUL1,HIGH);
   delayMicroseconds(500);
   digitalWrite(PUL1,LOW);
void s_l()                            //steps to the left
   digitalWrite(DIR1,LOW);
void shutdown_1()                       // Engine Shutdown
 void return_1()                    //loopback
   teta1=0;
Hello guess. Edit your post and move all your formatted code into a code box by clicking the "</>" and pasting your code where it says "paste code here"
// ratio = 13.73:1
// driver dm542t
int PUL1 = 10;
int DIR1 = 11;
int SET1 = 14;
String data;
     teta1 = num1;
     teta2 = num2;
     teta3 = num3;
     teta4 = num4;
     teta5 = num5;
     teta6 = num6;
      s_l();
       s_r();
   delay(2000);
teta1=0;
Have you ever just printed the received string on the serial monitor? Let's start at the beginning and see where the problem is located.
ok, i will edit it.
@guess29, please do not cross-post. Threads merged (and moved).
You might get some good ideas from reading Serial Input Basics - updated.
Actually OP does; after receiving a '\n'.
