I have a difficulty when I try to continuously run my stepper motor using application created in MIT APP2,this is the code on Arduino Uno:
#include <SoftwareSerial.h>
int Incoming_value = 8;//vrijednost primljena s aplikacije putem bluetooth modula
//String Outgoing_sensorValues = "start0/0/0/0end";
const int stepPin = 6; //PUL -Pulse Motor 1
const int dirPin = 3; //DIR -Direction Motor 1
const int enPin = 5; //ENA -Enable Motor 1
const int stepPin2 = 11; //PUL -Pulse Motor 2
const int dirPin2 = 10; //DIR -Direction Motor 2
const int enPin2 = 9; //ENA -Enable Motor 2
SoftwareSerial hc06(2,4);
pinMode(13,OUTPUT);
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(enPin,OUTPUT);
digitalWrite(enPin,LOW);
pinMode(stepPin2,OUTPUT);
pinMode(dirPin2,OUTPUT);
pinMode(enPin2,OUTPUT);
digitalWrite(enPin2,LOW);
hc06.begin(9600);
delay(200);
if(hc06.available()>0)
Incoming_value = hc06.read();
Serial.println(Incoming_value);
int sensorValue = analogRead(A0);
int sensorValue1 = analogRead(A1);
int sensorValue2 = analogRead(A2);
int sensorValue3 = analogRead(A3);
//Outgoing_sensorValues = "start0/0/0/0end";
//Outgoing_sensorValues = String("start" + String(sensorValue1) + '/' + String(sensorValue2) + '/' + String(sensorValue3) + '/' + String(sensorValue) + "end");
//delay(100);
// Serial.println(Outgoing_sensorValues);
if(Incoming_value == 1){//strelica gore
Serial.println("Forward");
digitalWrite(dirPin,HIGH);
for(int x = 0; x < 100; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(2000);
digitalWrite(stepPin,LOW);
//Makes 200 Pulses for making one full cycle rotation
else if(Incoming_value == 2){//strelica dolje
digitalWrite(dirPin,LOW);
// Makes 200 pulses for making one full cycle rotation
else if(Incoming_value == 3){//strelica livo
digitalWrite(dirPin2,HIGH);
for(int x = 0; x < 50; x++){
digitalWrite(stepPin2,HIGH);
digitalWrite(stepPin2,LOW);
else if(Incoming_value == 4){//strelica desno
digitalWrite(dirPin2,LOW);
else if(Incoming_value == 8){//promjena moda rada
else {
void auto_mod(){
int Y = sensorValue1 - sensorValue2;
int X = sensorValue3 - sensorValue;
delay(10);
if((X<-20)&&(Y<-20)) //oba manja
for(int x = 0; x < 100; x++){
else if((X>20)&&(Y>20)) //oba veća
else if((X<-20)&&(Y>20)) //X manji Y veći
else if((X>20)&&(Y<-20)) //X veći Y manji
else if((X<-20)&&((Y<20)&&(Y>-20))) //X manji Y dobar
//digitalWrite(dirPin2,LOW);
//digitalWrite(stepPin2,HIGH);
//digitalWrite(stepPin2,LOW);
else if((X>20)&&((Y<20)&&(Y>-20))) //X veći Y dobar
//digitalWrite(dirPin2,HIGH);
else if(((X<20)&&(X>-20))&&(Y<-20)) //X dobar Y manji
//digitalWrite(dirPin,LOW);
//digitalWrite(stepPin,HIGH);
//digitalWrite(stepPin,LOW);
else if(((X<20)&&(X>-20))&&(Y>20)) //X dobar Y veći
else{
delay(100);
This is what i get in serial monitor:
Motor only moves one cycle,I want it to move continuously,as long as i hold the button in an application,this is the app block diagram:
