Sending Data from Arduino to C# Windows Forms
So I'm quite confused on how to send any kind of information from Arduino to C#. I've seen a post which explained how to do for Console App. Now I'm trying to "convert" this code to Windows Forms, since it's a bit different, but I'm quite a newbie in programming, so I don't really know how. What I need is basically that when I press a button (PULL-UP), it sends to C# a text (such as "You've pressed the button), by using label. Basically editing "label1" text to "You've pressed the button" text.
Here's the code:
internal class Program
         static SerialPort serialPort;
         static void Main(string[] args)
             serialPort = new SerialPort();
             serialPort.PortName = "COM5";
             serialPort.BaudRate = 9600;
             serialPort.Open();
             while(true)
                 string a = serialPort.ReadExisting();
                 Console.WriteLine(a);
                 Thread.Sleep(1000);
Looking at his code in Excel might give some hints?
Not really, I'm sorry...
this is a VERY basic C# application using the SerialPort component it opens COM4 at 115200baud then in a loop reads lines of text and displays on console
using System;
using System.IO.Ports;
namespace ConsoleTerminal
    class Program
            SerialPort serialPort = new SerialPort() ;
            serialPort.PortName = "COM4";
            serialPort.BaudRate = 115200;
            serialPort.Open();
            while (true)
                string s = serialPort.ReadLine();
                Console.WriteLine(s);
you can create a form and when characters are received from a COM port display them in a TextBox. You can create menus to select the COM port, setup baudrate, etc etc etc
Edit: realised code is similar to yours of post #1 - what exactly do you require hlep with the Arduino code or the C# code?
Edit: have a look at terminal emulators implemented in VB and C#
It's with the C#. In the C# Console App, yes that code works. but the problem is with the TextBox that I don't know how to make the data, that recieved (in this case a simple button pressing) in a text. Literally when I press a button, I want a text to appear on the TextBox
this is a screen shot the C# terminal emulator I gave the github link too in post #4
Csharp_terminalEmulator
you can see the TextBox which is displaying the text received from a ESP8266 on COM11
you can download the complete Visual Studio project and modify it to suit your requirements
Edit: I am building it (hit Ctrl/F5 to build and run) with
Microsoft Visual Studio Community 2022 (64-bit) - Current Version 17.1.2
Thank you, I'll look into it
