I am trying to send data from ultrasonic sensors and my DHT22 Temperature and Humidity sensors to mySQL Database named 'node-red'. However, when I try uploading the code it gives me an 'error compiling for board to Arduino/Genuino Uno'. I usually restart my whole system and the code works after such an error, but it dosen't fix the problem in this case. I am using Arduino IDE 1.8.10 and followed the instructions here:
http://commenthow.com/article/display/5218/0/Connecting+Arduino+to+MySQl+database+w%252F+USB+using+MysqlIO
However, after following the instructions, I am stuck at Step 4. Any advice?
#include <DHT.h>;
#include <Servo.h>
#include <mysql.h>
//Constants
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
const int trigPin = 9;
const int echoPin = 10;
const int trigPin1 = 6;
const int echoPin1 = 7;
const int trigPin2 = 11;
const int echoPin2 = 12;
//Variables
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
long duration;
float distance;
long duration1;
float distance1;
long duration2;
float distance2;
char *host, *user, *pass, *db;
int isconnected = 0;
Servo servo;
pinMode(LED_BUILTIN, OUTPUT);
servo.attach(8);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(trigPin1, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin1, INPUT); // Sets the echoPin as an Input
pinMode(trigPin2, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin2, INPUT); // Sets the echoPin as an Input
dht.begin();
host = "192.168.1.76";
user = "root";
pass = "LINUX@1991v6";
db = "node-red";
isconnected = mysql_connect(host,user,pass,db);
if(isconnected){
Serial.print("Connected to ");
Serial.println(host);
else{
Serial.println("Connection failed.");
mysql_close();
void loop(){
infront();
rightside();
leftside();
temperature();
void temperature()
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print(hum);
Serial.print(" , ");
Serial.print(temp);
Serial.print(distance);
Serial.print(distance1);
Serial.print(distance2);
delay(500); //Delay 2 sec.
void infront() {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
if (distance < 100){
servo.write(90);
delay(100);
servo.write(0);
delay(100);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
else{
servo.write(0);
digitalWrite(LED_BUILTIN, LOW);
delay(100);
void leftside() {
digitalWrite(trigPin1, LOW);
digitalWrite(trigPin1, HIGH);
duration1 = pulseIn(echoPin1, HIGH);
distance1= duration1*0.034/2;
if (distance1 < 100){
servo.write(90);
delay(100);
servo.write(0);
delay(100);
delay(100);
else{
servo.write(0);
delay(100);
void rightside() {
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
distance2= duration2*0.034/2;
if (distance2 < 100){
servo.write(90);
delay(100);
servo.write(0);
delay(100);
delay(100);
else{
servo.write(0);
delay(100);
The error is shown below:
Arduino: 1.8.10 (Linux), Board: "Arduino/Genuino Uno"
/home/thomas/Documents/Temp/Temp.ino:1:17: warning: extra tokens at end of #include directive
#include <DHT.h>;
/home/thomas/Documents/Temp/Temp.ino: In function 'void setup()':
/home/thomas/Documents/Temp/Temp.ino:43:10: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
host = "localhost";
/home/thomas/Documents/Temp/Temp.ino:44:10: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
user = "root";
/home/thomas/Documents/Temp/Temp.ino:45:10: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
/home/thomas/Documents/Temp/Temp.ino:46:8: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
db = "node-red";
/home/thomas/Arduino/libraries/mysql/mysql.cpp: In function 'int mysql_connect(char*, char*, char*, char*)':
/home/thomas/Arduino/libraries/mysql/mysql.cpp:31:5: error: redefinition of 'int mysql_connect(char*, char*, char*, char*)'
int mysql_connect(char *host, char *user, char *pass, char *db){
/home/thomas/Arduino/libraries/mysql/mysql.cpp:10:5: note: 'int mysql_connect(char*, char*, char*, char*)' previously defined here
/home/thomas/Arduino/libraries/mysql/mysql.cpp: In function 'String mysql_result_query(String, String)':
/home/thomas/Arduino/libraries/mysql/mysql.cpp:67:10: error: conversion from 'int' to 'String' is ambiguous
return 0;
In file included from /home/thomas/Downloads/arduino-1.8.10/hardware/arduino/avr/cores/arduino/Arduino.h:231:0,
from /home/thomas/Arduino/libraries/mysql/mysql.cpp:7:
Multiple libraries were found for "mysql.h"
Used: /home/thomas/Arduino/libraries/mysql
Multiple libraries were found for "Adafruit_Sensor.h"
Used: /home/thomas/Arduino/libraries/Adafruit_Unified_Sensor
Multiple libraries were found for "DHT.h"
Used: /home/thomas/Arduino/libraries/DHT_sensor_library
Multiple libraries were found for "Servo.h"
Used: /home/thomas/Downloads/arduino-1.8.10/libraries/Servo
/home/thomas/Downloads/arduino-1.8.10/hardware/arduino/avr/cores/arduino/WString.h:61:2: note: candidate: String::String(const __FlashStringHelper*)
String(const __FlashStringHelper str);
/home/thomas/Downloads/arduino-1.8.10/hardware/arduino/avr/cores/arduino/WString.h:59:2: note: candidate: String::String(const char)
String(const char *cstr = "");
/home/thomas/Arduino/libraries/mysql/mysql.cpp:71:10: error: conversion from 'int' to 'String' is ambiguous
return 0;
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
