Sending data from Arduino to Python
Hello
I’m sending data to python from my Arduino and I’m having some difficulties. My program on the python side is not working and I’m curious if the string I’m sending is in the correct format. (Arduino 1.0 and Python 2.7.2 and pySerial 2.5)
Here is the Arduino code:
Serial.begin (115200);
Serial.println("{'p1':'1010','p2':'756','p3':'395','p4':'10','p5':'897','p6':'1024'}");
This should be interpreted by python as a regular dictionary with strings as keys and values.
Below is the Python code:
import serial
usbport ='/dev/tty.usbserial-A600af58'
ser = serial.Serial(usbport, 115200, timeout=1)
RawData=ser.readline()
for i in range (10):
    print RawData
print RawData['p2']
I get an error when trying to read one of the dictionary keys.
Python 2.7.2 (v2.7.2:8527427914a2, Jun 11 2011, 14:13:39)
[GCC 4.0.1 (Apple Inc. build 5493)] on darwin
Type "copyright", "credits" or "license()" for more information.
{'p1':'1010','p2':
Traceback (most recent call last):
  File "/Users/mdsmac/Dropbox/MiniMe/Software/Currently version in use/Sens_Input_Dict0618.py", line 11, in <module>
    print RawData['p2']
TypeError: string indices must be integers, not str
Is Arduino sending what Python reads as a string or is it something else?
Thanks
the data you send from arduino to pc (python in this case) is a string. so if you want it to be converted to a table, then you'll have to process the string, looking for matches (you could use regex).
because you try to read data from a table with index 'p2', while the received data is a string format.
