I am having some difficulty sending data from the Arduino BT to my MAC. I know that I can communicate from my Laptop to the Arduino because I was able to do the Blink program. However, I am now hooking up my circuit to the Arduino BT and I need it to transfer the data, via Bluetooth, to my Laptop where I am running LabView.
I have the Arduino BT Mega238P with the Bluetooth device already mounted on it. Any help would be appreciated.
Yes, I have hooked it up and the communication from my computer to the Arduino works great. However, I am using Serial.println("ON"); everytime the light turns on just to see if I can get a response from my Arduino, and it doesn't work.
I am able to upload the code. I am trying to get the Arduino to reply back just to ensure that I have 2 way communication. I am programming dumb, so this may be a simple fix. I am just utilizing the Blink program and telling the Arduino to send back an ON or OFF message when the light is on/off. I open the Serial Monitor window and set the baud rate to 9600. The code looks like this:
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards:
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(13, LOW); // set the LED off
Serial.println("OFF");
Uploading sketches requires two-way serial communications so your bluetooth connection SHOULD be working. Try the 115200 baud setting mentioned in the user's guide:
"Using the Arduino BT
The on-board serial communication between the bluetooth module and the Arduino sketch (running on the ATmega168) needs to be at 115200 baud (i.e. call Serial.begin(115200) in your setup() function). Communication between the bluetooth module and the computer can be at any baud rate.
Communication between the BT module and the computer can be temperamental. You might want to open the serial monitor a couple of seconds after resetting the board."
If I use the Serial.begin(115200), that sets the communication rate on the board? But it doesnt effect the communication between the Arduino and the computer? So, when I open the Serial Monitor, what baud rate do I select? I've been through them all.
The command Serial.println("ON") should tell the Arduino to send back "ON" to my computer via Bluetooth, right?
