Hello, I am trying to send data from 3 sensors on one nano to another nano connected to a tca9548a with 4 LCDs on channels 1 to 4 via an nrf24l01. I can send and receive the data through the serial monitor but I cannot get it to print on the LCDs. I have tried ChatGPT and Deepseek to write the code, but it does not work. I want the Accelerator data on one LCD, the Gyroscope data on another, the compass data and angles on another LCD, and the temperatures on the 16x2.
My wiring is:
nRF24L01
miso to D12
mosi to D11
sck to D13
ce to D9
csn to D10.
tca9548a
SCL to A5
SDA to A4
My imu code is:
#include <Wire.h>
#include <QMC5883LCompass.h>
#include <SPI.h>
#include "max6675.h"
// Compass object
QMC5883LCompass compass;
// MAX6675 sensor pins
int thermoDO = 6;
int thermoCS = 5;
int thermoCLK = 13;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
// Gyro and accelerometer variables
float RateRoll, RatePitch, RateYaw;
float AccX, AccY, AccZ;
float AngleRoll, AnglePitch;
float RateCalibrationRoll, RateCalibrationPitch, RateCalibrationYaw;
void initMPU6050() {
Wire.beginTransmission(0x68);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission();
delay(100);
void readMPU6050() {
Wire.write(0x3B);
Wire.requestFrom(0x68, 14);
int16_t AccXLSB = Wire.read() << 8 | Wire.read();
int16_t AccYLSB = Wire.read() << 8 | Wire.read();
int16_t AccZLSB = Wire.read() << 8 | Wire.read();
Wire.read(); Wire.read(); // Skip temperature
int16_t GyroX = Wire.read() << 8 | Wire.read();
int16_t GyroY = Wire.read() << 8 | Wire.read();
int16_t GyroZ = Wire.read() << 8 | Wire.read();
RateRoll = (float)GyroX / 65.5 - RateCalibrationRoll;
RatePitch = (float)GyroY / 65.5 - RateCalibrationPitch;
RateYaw = (float)GyroZ / 65.5 - RateCalibrationYaw;
AccX = ((float)AccXLSB / 4096) - 0.05;
AccY = ((float)AccYLSB / 4096) - 0.02;
AccZ = ((float)AccZLSB / 4096) + 0.02;
AngleRoll = atan2(AccY, sqrt(AccX * AccX + AccZ * AccZ)) * (180.0 / PI);
AnglePitch = -atan2(AccX, sqrt(AccY * AccY + AccZ * AccZ)) * (180.0 / PI);
Serial.begin(57600);
Wire.begin();
Wire.setClock(400000);
delay(250);
initMPU6050();
compass.init();
Serial.println("Calibrating Gyro...");
for (int i = 0; i < 2000; i++) {
readMPU6050();
RateCalibrationRoll += RateRoll;
RateCalibrationPitch += RatePitch;
RateCalibrationYaw += RateYaw;
delay(1);
RateCalibrationRoll /= 2000;
RateCalibrationPitch /= 2000;
RateCalibrationYaw /= 2000;
Serial.println("Calibration Complete.");
Serial.println("MAX6675 Initialized");
int x, y, z;
float azimuth, elevation;
// Read Compass Data
compass.read();
x = compass.getX();
y = compass.getY();
z = compass.getZ();
azimuth = atan2(y, x) * (180.0 / PI);
elevation = atan2(z, x) * (180.0 / PI);
Serial.print("---------------------------------------------\n");
Serial.print("Compass - Azimuth: ");
Serial.print(azimuth);
Serial.print("°, Elevation: ");
Serial.println(elevation);
// Read Gyroscope and Accelerometer
readMPU6050();
Serial.print("Gyro - Roll Rate: "); Serial.print(RateRoll);
Serial.print("°/s, Pitch Rate: "); Serial.print(RatePitch);
Serial.print("°/s, Yaw Rate: "); Serial.println(RateYaw);
Serial.print("Accel - X: "); Serial.print(AccX);
Serial.print(" g, Y: "); Serial.print(AccY);
Serial.print(" g, Z: "); Serial.println(AccZ);
Serial.print("Angles - Roll (X-axis): "); Serial.print(AngleRoll);
Serial.print("°, Pitch (Y-axis): "); Serial.println(AnglePitch);
// Read MPU6050 Temperature
Wire.write(0x41);
Wire.requestFrom(0x68, 2);
int16_t tempRaw = Wire.read() << 8 | Wire.read();
float sensorTemp = (tempRaw / 340.0) + 36.53;
Serial.print("Sensor Temp: "); Serial.print(sensorTemp); Serial.println("°C");
// Read MAX6675 Thermocouple
float telescopeTemp = thermocouple.readCelsius();
Serial.print("Telescope Temp: "); Serial.print(telescopeTemp); Serial.println("°C");
delay(2000);
This does not include the nRF24L01 part because I am unsure if that is the problem.
Here is a basic illustration of my wiring:
Any help would be much appreciated.
