Hi, I am working on a project which is designed to test 4 wire PWM Fans. I have been asked to use two Arduino Uno, as Master and Slave. I found a working code from a forum posted by @dlloyd . As I read through the forum, I found the PWM signals are being generated by a subroutine called void pwmDuty (). My question is, how do I send the PWM signals to the slave Arduino? I usedboth the wire.Write(ocrb) and wire.Write(pwmDuty) but it shows error. Any help will be great!
#include <Wire.h>
unsigned long startTime;
int pwmOut=3;
int pwm=0 ;
int duty;
byte ocrb;
int half_revolutions = 0;
int rpm = 0;
unsigned long lastmillis = 0;
int i=0;
int minim = 12000;
int maxim = 0;
int Judgment=0;
int Delta=0;
float DutyCycle;
pwm25kHzBegin();
pinMode(pwmOut, OUTPUT);
Wire.begin();
attachInterrupt(0, rpm_fan, FALLING);
void loop(){
// pwmDuty(19); // 25% (range = 0-79 = 1.25-100%)
// delay(5000);
// pwmDuty(39); // 50% (range = 0-79 = 1.25-100%)
// delay (5000);
pwmDuty(11); // 75% (range = 0-79 = 1.25-100%)
if (millis() - lastmillis == 1000){ //Uptade every one second, this will be equal to reading frecuency (Hz).
detachInterrupt(0);//Disable interrupt when calculating
if (i<20) {
//for (i; i<21; i++) {
rpm = half_revolutions * 30; // Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use half_revolutions * 30.
if ( rpm > maxim ) maxim =rpm;
if ( rpm < minim ) minim = rpm;
Serial.print("RPM =\t"); //print the word "RPM" and tab.
Serial.println(rpm); // print the rpm value.
//Serial.print("\t Hz=\t"); //print the word "Hz".
//Serial.println(half_revolutions); //print revolutions per second or Hz. And print new line or enter.
if ( i == 19 ){
if (minim<4050) Judgment=1;
if (maxim>4950) Judgment=1;
Delta=maxim-minim;
if (Delta>600) Judgment=1;
Serial.print ("Min=\t");
Serial.print(minim);
Serial.print ("\t Max=\t");
Serial.println(maxim);
Serial.print ("\t Delta=\t");
Serial.println(Delta);
if (Judgment==1) Serial.println("Fail");
else Serial.println ("Pass");
i++;
half_revolutions = 0; // Restart the RPM counter
lastmillis = millis(); // Uptade lasmillis
attachInterrupt(0, rpm_fan, FALLING); //enable interrupt
Wire.beginTransmission(1);
delay(11);
Wire.write(pwmDuty);
Wire.endTransmission();
delay(50);
void pwm25kHzBegin() {
TCCR2A = 0; // TC2 Control Register A
TCCR2B = 0; // TC2 Control Register B
TIMSK2 = 0; // TC2 Interrupt Mask Register
TIFR2 = 0; // TC2 Interrupt Flag Register
TCCR2A |= (1 << COM2B1) | (1 << WGM21) | (1 << WGM20); // OC2B cleared/set on match when up/down counting, fast PWM
TCCR2B |= (1 << WGM22) | (1 << CS21); // prescaler 8
OCR2A = 79; // TOP overflow value (Hz)
OCR2B = 0;
void pwmDuty(byte ocrb) {
OCR2B = ocrb; }
void rpm_fan(){
half_revolutions++;
