Sending data from mysql via php to arduino
Hello, I'm trying to receive data from the MySQL server hosted on AwardSpace to my Arduino MEGA2560 using the SIM7600CE, but I'm not receiving any response.
Code MySQL
<?php
// Create connection
$conn = new PDO('sqlite:readingsDB.sqlite');
// Vérifier la connexion
if (!$conn) {
    die("Connection failed");
// Requête SQL pour récupérer les données
$sql = "SELECT humidity FROM reading ORDER BY distance DESC LIMIT 1";
$result = $conn->query($sql);
if ($result) {
    // Tableau pour stocker les données
    $data = array();
    // Récupérer chaque ligne de résultat
    while($row = $result->fetch(PDO::FETCH_ASSOC)) {
        // Ajouter les données à $data
        $data[] = $row;
    // Convertir le tableau en format JSON
    $json_data = json_encode($data);
    // Renvoyer les données au format JSON
    echo $json_data;
    echo "0 results";
I have added a new file named "test.json" for testing purposes.
JsonDocument doc;
doc["sensor"] = "gps";
doc["time"] = 1351824120;
doc["data"][0] = 48.756080;
doc["data"][1] = 2.302038;
serializeJson(doc, Serial);
// This prints:
// {"sensor":"gps","time":1351824120,"data":[48.756080,2.302038]}
Code Arduino
/*Ce code utilise la bibliothèque TinyGSM: https://github.com/vshymanskyy/TinyGSM
 * pour le module GSM SIM7600
 * Code version 0.3 GSM
#define TINY_GSM_MODEM_SIM7600//SIM7600 pour la library GSM fonction network
// Define how you're planning to connect to the internet.
// This is only needed for this example, not in other code.
#define TINY_GSM_USE_GPRS true
#define TINY_GSM_USE_WIFI false
#define TINY_GSM_YIELD() { delay(2); }//reception delay
#define TINY_GSM_RX_BUFFER 650//obligatoir pour les cartes Arduino
// Set serial for debug console (to the Serial Monitor, speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#ifndef __AVR_ATmega328P__
#define SerialAT Serial3
// or Software Serial on Uno, Nano
#else
#include <SoftwareSerial.h>
SoftwareSerial SerialAT(7,8);  // RX, TX
#endif
#include "timer.h" //rajouter le fichier source timer.cpp pour l'utilisation des timers
#include "temperature.h"
#include <TinyGsmClient.h>
#define TINY_GSM_DEBUG SerialMon//pour debuger
#include <ArduinoJson.h>
#include <SPI.h>
TinyGsm SIM7600CE(SerialAT);
TinyGsmClient client(SIM7600CE);
const char apn[]  = "F Free Free "; // Change this to your Provider details
const char gprsUser[] = "";
const char gprsPass[] = "";
const char server[] = "sms-ileo.atwebpages.com"; // Change this to your selection
const char resource[] = "/insert.php";
const char path[] = "/test.json"; // Chemin vers le script PHP
const int  port = 80;
unsigned long timeout;
  timerConfig();//pré-config des timers
  temperatureInit();
  SerialMon.begin(115200);
  delay(10);
  //Debut du boot auto
  pinMode(12,OUTPUT);
  digitalWrite(12,1);
  digitalWrite(12,0);
  //fin du boot auto
  SerialMon.println("Wait...");
  SerialAT.begin(115200);//met la com UART 115200 pour le module GSM
  //rajouter une fonction de reboot en cas de non reponse de la part du shield GSM
  delay(600);
  SerialMon.println("Initializing SIM7600CE...");
  // Déverrouillage de la carte SIM avec le code PIN
  SerialMon.println("Unlocking SIM card...");
  if (!unlockSIMCard("1234")) { // code PIN
    SerialMon.println("Failed to unlock SIM card!");
    return;
  SerialMon.println("SIM card unlocked successfully!");
//routine ISR pour interruption externe
//routine ISR pour interruption timer
ISR (TIMER4_OVF_vect)
   nbCycleTimer4_g=nbCycleTimer4_g+1;
    if(nbCycleTimer4_g < (nbCyclePgrm_g+1))
          if(nbCycleTimer4_g == nbCyclePgrm_g )//test passage de 15 à 20
            SerialMon.println("Objectif timer 4 (PGRM) atteint! ");
            timerPgrm_g=1;
            nbCycleTimer4_g=0;//raz
    else nbCycleTimer4_g=0;//raz
  TCNT4H=0x00;
  TCNT4L=0x00;
ISR (TIMER3_OVF_vect)
  nbCycleTimer3_g=nbCycleTimer3_g+1;
    if(nbCycleTimer3_g < (nbCycleGsm_g+1))
          if(nbCycleTimer3_g == nbCycleGsm_g )//test passage de 15 à 20
            sei();
            SerialMon.println("Objectif timer 3 (GSM) atteint! ");
            sendDataTempServeur();
            getdatafromserver();
            cli();
            timerGsm_g=1;
            nbCycleTimer3_g=0;//raz
    else nbCycleTimer3_g=0;//raz
  TCNT3H=0x00;
  TCNT3L=0x00; //reset à chaque passage pour l'overflow
  //timerGsm_go(60); //cycle total 60 secondes
  //timerPgrm_go(60); //cycle total 60 secondes
  SIM7600CE.init();//si beug remplacer par restart
  SerialMon.print("Waiting for network...");
  String modemInfo = SIM7600CE.getModemInfo();
  SerialMon.print("Modem Info: ");
  SerialMon.println(modemInfo);//information du module
  if (!SIM7600CE.waitForNetwork()) {
    SerialMon.println(" erreur: La connexion n'a pas pu être établie!");
    // SIM7600CE.sendSMS(SMS_TARGET, String("ILEO erreur: La connexion au réseau mobile n'a pas pu être établie!!"));//fonction pour l'envoi de SMS
    delay(600);
    return;
  SerialMon.println(" success");
  if (SIM7600CE.isNetworkConnected()) {SerialMon.println("Network connected!");}
  SerialMon.print(F("Connecting to "));
  SerialMon.print(apn);
  if (!SIM7600CE.gprsConnect(apn, gprsUser, gprsPass)) {
    SerialMon.println(" fail");
    return;
  if (SIM7600CE.isGprsConnected()) {
    SerialMon.println("GPRS connected");
  timerGsm_go(30); //cycle total 30 secondes envoi des data sur serveur
  while(1)//program principal
// ---------------------------- Fonction de déverrouillage de la carte SIM -----------------------------
bool unlockSIMCard(const char* pin) {
  SerialAT.println("AT+CPIN=\"" + String(pin) + "\"");
  String response = SerialAT.readString();
  return response.indexOf("OK") != -1;
// -------------------------------------- Fonction d'Envoie sms ----------------------------------------
void sendSMS(String number, String message) {
      SerialAT.println("AT+CMGF=1"); // Configuration du mode texte
      delay(100);
      SerialAT.print("AT+CMGS=\""); // Commande pour spécifier le numéro de téléphone
      SerialAT.print(number);
      SerialAT.println("\"");
      delay(100);
      SerialAT.print(message); // Contenu du SMS
      delay(100);
      SerialAT.println((char)26); // Envoi du message (Ctrl+Z)
      delay(100);
// ---------------------------------- Fonction de Récupération des données -----------------------------
void getdatafromserver(void){
  // Send HTTP request
   client.print("GET ");
    client.print(path);
    client.println(" HTTP/1.0");
    client.print("Host: ");
    client.println(server);
    client.println(F("Connection: close"));
  if (client.println() == 0) {
    Serial.println(F("Failed to send request GET"));
    client.stop();
    return;
  // Check HTTP status
  char status[32] = {0};
  client.readBytesUntil('\r', status, sizeof(status));
  // It should be "HTTP/1.0 200 OK" or "HTTP/1.1 200 OK"
  if (strcmp(status + 9, "200 OK") != 0) {
    Serial.print(F("Unexpected response: "));
    Serial.println(status);
    client.stop();
    return;
  // Skip HTTP headers
  char endOfHeaders[] = "\r\n\r\n";
  if (!client.find(endOfHeaders)) {
    Serial.println(F("Invalid response"));
    client.stop();
    return;
  // Allocate the JSON document
  JsonDocument doc;
  // Parse JSON object
  DeserializationError error = deserializeJson(doc, client);
  if (error) {
    Serial.print(F("deserializeJson() failed: "));
    Serial.println(error.f_str());
    client.stop();
    return;
  // Extract values
  Serial.println(F("Response:"));
  Serial.println(doc["sensor"].as<const char*>());
  Serial.println(doc["time"].as<long>());
  Serial.println(doc["data"][0].as<float>(), 6);
  Serial.println(doc["data"][1].as<float>(), 6);
  // Disconnect
  client.stop();
// ------------------------------ Fonction d'envoie des données au serveur -----------------------------
void sendDataTempServeur(void) {
    if (!client.connect(server, port)) {
        SerialMon.println("Impossible de se connecter au serveur !");
        return;
    const float temperature = 80;
    SerialMon.print("Temperature: ");
    SerialMon.println(temperature);
    SerialMon.println("Envoi de la requête HTTP POST...");
    String httpRequestData = "key=a@4K%3&distance=" + String(temperature) + "&temperature=" + String(temperature) + "&temperature=" + String(temperature);
    client.print("POST ");
    client.print(resource);
    client.println(" HTTP/1.1");
    client.println("Connection: close");
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.print("Content-Length: ");
    client.println(httpRequestData.length());
    client.println();
    client.println(httpRequestData);
    // Attendre la réponse du serveur
    while (client.connected() && !client.available()) {
        delay(1);
    SerialMon.println("FIN de la requête HTTP POST...");
    // Fermer la connexion
    client.stop();
post the full arduino code using code tags properly (please read How to get the best out of this forum as I had to fix your first post).
explain also if you have proper connectivity to your server from MEGA2560 using the SIM7600CE
Are you sure your database is a MySQL?
In your PHP script you are using a SQLite driver and it's not the same thing.
What do you see when you issue the URL embedded in the GET request to the PHP script from a web browser ? Do you see some representation of this: echo $json_data ?
Thank you for your response. I have now published all the Arduino code.
I see the value
[{"humidity":60}]
but i can post value to the web server
