Sending data from sensor using Bluetooth
Hi everybody I'm a newbiee and I have a problem.
I'm trying to read the values of a pot from Arduino UNO using a Bluetooth shield (http://www.seeedstudio.com/depot/bluetooth-shield-p-866.html).
I can read the values if I open the serial monitor using COM3 (which is the USB COM I use to program the Arduino), but when I try to read the values using COM4 or COM6 (which are the COMs that the computer created when I paired the bluetooth shield), I can't see anything.
Here is my code:
#include <SoftwareSerial.h>
#define RxD 6
#define TxD 7
#define DEBUG_ENABLED  1
SoftwareSerial blueToothSerial(RxD,TxD);
int sensorPin = A0;
int sensorValue = 0;
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
void setupBlueToothConnection()
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=OSC_BT_\r\n"); //set the bluetooth name as "SeeedBTSlave"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
  sensorValue = analogRead(sensorPin);
  Serial.println(sensorValue);
  delay(100);
I hope somebody can help, I'd like to sleep tonight.
Thanks and sorry for my bad english.
I am very interested in this as well. Please let me know if you find a solution. I am using a Arduino Uno and a RN41 Bluetooth module (http://www.sparkfun.com/products/10559) and am having trouble. Thanks!
My mistake was that I used serial.print instead of "bluetoothserial.print"
