Sending data from two Serial ports to another Serial port
Hello,
As mentioned in the title, I'm trying to send the data that I got from two other serial ports by using another serial port.
The serial ports I use to receive data: Serial2 and Serial3
The serial port that I want to use to send the received data in Serial2 and Serial3: Serial1
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
TinyGPSPlus gps1;
TinyGPSPlus gps2;
char data_1;
char data_2;
double  lat1;
double  lat2;
double  lon1;
double  lon2;
TinyGPSCustom pdop(gps1, "GPGSA", 15);
TinyGPSCustom pdop2(gps2, "GPGSA", 15);
TinyGPSCustom vdop(gps1, "GPGSA", 17);
TinyGPSCustom vdop2(gps2, "GPGSA", 17);
   Serial1.begin(4800);
   Serial2.begin(4800);
   Serial3.begin(4800);
   pinMode(13, OUTPUT); //LED
   pinMode(18, OUTPUT); //LED
   pinMode(19, OUTPUT); //LED
   pinMode(20, OUTPUT); //DE
   pinMode(21, OUTPUT); //RE#
  while (Serial3.available() > 0) //Second GPS receiver
    if (gps1.encode(Serial3.read())){
      displayInfo1(); //function to print variables such as time, speed and course.
      afstand_bearing_koers(); //function to print variables such as distance and bearing between two GPS receivers.
      digitalWrite(18, HIGH);
  if (millis() > 5000 && gps1.charsProcessed() < 10)
    Serial.println(F("GPS1 niet gevonden: check bedrading."));
    while(true);
  while (Serial2.available() > 0) //First GPS receiver
    if (gps2.encode(Serial2.read())){
      displayInfo2();  //function to print variables such as time, speed and course.
      digitalWrite(19, HIGH);
  if (millis() > 5000 && gps2.charsProcessed() < 10)
    Serial.println(F("GPS2 niet gevonden: check bedrading."));
    while(true);
void displayInfo1() //printing relevant data from the received nmea-sentences starts here.
  Serial.print(F("GPS1: "));
  if (gps1.location.isValid())
    lat1 = gps1.location.lat();
    Serial.print(lat1, 6);
    Serial.print(F(","));
    lon1 = gps1.location.lng();
    Serial.print(lon1, 6);
    Serial.print(F(" "));
    Serial.print(F("INVALID"));
  if (gps1.speed.isValid())
    Serial.print(gps1.speed.knots());
    Serial.print(gps1.speed.kmph());
  if (gps1.course.isValid())
    Serial.print(gps1.course.deg());
  if (gps1.time.isValid())
    if (gps1.time.hour() < 10) Serial.print(F("0"));
    Serial.print(gps1.time.hour());
    Serial.print(F(":"));
    if (gps1.time.minute() < 10) Serial.print(F("0"));
    Serial.print(gps1.time.minute());
    if (gps1.time.second() < 10) Serial.print(F("0"));
    Serial.print(gps1.time.second());
    Serial.print(" ");
    if (gps1.altitude.isValid() && gps1.satellites.isValid() &&
    gps1.hdop.isValid())
    Serial.print(F("ALT= "));  Serial.print(gps1.altitude.meters());
    Serial.print(" PDOP= ");    Serial.print(pdop.value());
    Serial.print("|");
    Serial.print(F(" HDOP= "));
    double h_dop = gps1.hdop.value();
    Serial.print(h_dop / 100);
    Serial.print(" ");
    Serial.print("VDOP= "); Serial.print(vdop.value());
    Serial.print("|");
    Serial.print(F(" SATS= ")); Serial.print(gps1.satellites.value());
void displayInfo2()
  Serial.print(F("GPS2: "));
  if (gps2.location.isValid()) //Laat locatie zien
    lat2 = gps2.location.lat();
    Serial.print(lat2, 6);
    lon2 = gps2.location.lng();
    Serial.print(lon2, 6);
  if (gps2.speed.isValid())
    Serial.print(gps2.speed.knots());
    Serial.print(gps2.speed.kmph());
  if (gps2.course.isValid())
    Serial.print(gps2.course.deg());
    Serial.print(F("INVALID "));
  if (gps2.time.isValid())
    if (gps2.time.hour() < 10) Serial.print("0");
    Serial.print(gps2.time.hour());
    Serial.print(":");
    if (gps2.time.minute() < 10) Serial.print("0");
    Serial.print(gps2.time.minute());
    Serial.print(":");
    if (gps2.time.second() < 10) Serial.print("0");
    Serial.print(gps2.time.second());
    Serial.print(" ");
    if (gps2.altitude.isValid() && gps2.satellites.isValid() &&
    gps2.hdop.isValid())
    Serial.print(F("ALT= "));  Serial.print(gps2.altitude.meters());
    Serial.print(" PDOP= "); Serial.print(pdop2.value());
    Serial.print("|");
    double h_dop_2 = gps2.hdop.value();
    Serial.print(h_dop_2 / 100);
    Serial.print(" ");
    Serial.print("VDOP= "); Serial.print(vdop2.value());
    Serial.print("|");
    Serial.print(F(" SATS= ")); Serial.print(gps2.satellites.value());
//void interpolatie(){
//  //punt maken zodat de afstand tussen twee nauwkeurigere punten gemeten kan worden
//  nieuwlat1 = 1.5*lat1;
//  nieuwlon1 = 1.5*lon1;
//  nieuwlat2 = 1.5*lat2;
//  nieuwlon2 = 1.5*lon2;
void afstand_bearing_koers(){
  if (gps1.location.isValid() && (gps2.location.isValid()))
  Serial.print(" Afstand= ");
  unsigned long afst =
  Serial.print((TinyGPSPlus::distanceBetween(
    lat1,
    lon1,
    lat2,
    lon2)));
  Serial.print(" Koers= ");
  double koers =
  Serial.print(TinyGPSPlus::courseTo(
    lat1,
    lon1,
    lat2,
    lon2));
  const char *cardinalGPS = TinyGPSPlus::cardinal(koers);
  Serial.print(" ");
  Serial.print(cardinalGPS);
  Serial.print(" ");
    Serial.print("INVALID");
  Serial.print("Referentiepunt= ");
  double ref =
  Serial.print(((lat1+lat2)/2),6);
  Serial.print(",");
  Serial.println(((lon1+lon2)/2),6);
I saw other people using Serial.write() to send data. But the functions that I use to print the relevant data from the GPS receivers are voids. So I can't use something like Serial.write(). So what can I do to send the same data by using Serial1 that I get in my Serial Monitor from Serial2 and Serial3?
Change "Serial.print" to "Serial1.print". If you want the output to go to both, make a copy of each "Serial.print..." line and change one of them to "Serial1.print...".
Thanks for the quick reply! I changed some of the Serial.print() to Serial1.print() and those data were not visible in the Serial Monitor, which is right. I think I should say that I'm using a USB-RS485-WE cable which is connected to the pins of Serial1. What happened just now was when I started receiving data via this cable, my cursor started moving rapidly and opened some other programs that were already openend, like crazy. Pulling the cable out stopped doing it. I think it's a software issue, but I have no idea where...
whenever I make DE (pin20) HIGH (to send data from Serial1), this problem starts.
Quite funny but strange, it works perfectly now!
